Help Request - Shims and Camshaft on 1983 XJ550 Maxim
Discussion in 'XJ Technical Chat' started by Rook_Defence, Aug 5, 2026.
  1. Rook_Defence
    Rook_Defence New Member
    Canada
    Hello, this is my first motorcycle, and I'm following the Clymer manual to catch up on any maintenance that may have been skipped by previous owners.
    The bike has just under 14000 km (less than 100 are mine) and seemed to be running decent. I've rebuilt the front brake system, adjusted drive chain tension, replaced oil/filter, adjusted timing chain tension, and I'm on to checking valve clearance and cleaning carbs now before I move on to syncing carbs. I just want to be sure I'm correctly understanding the following observations before I continue my work.
    My valve clearances seem to be very tight. On my intake valves had two measuring in spec (barely), and two over tight, with one at 0.076-0.089mm clearance, one at 0.038-0.051 clearance.
    Only one of my exhaust valves was in spec, and the others were around 0.102-0.114mm, 0.139-0.152mm, and 0.127-0.140mm clearance.
    Also, the condition of the camshaft is questionable. There's a "frosted" appearance on a couple cam lobes that I confirmed is a very shallow pitting using a pocket microscope. The borders of the machined/polished and unfinished areas of the camshaft are also a little uneven. Photos attached.
    So, I have the tool for depressing the buckets for shim removal being shipped now, but I need to clarify a couple things:
    1. Is it common for shims to be over tight from factory? To the best of my knowledge the previous owners never put in new shims. There were a few neglected tasks like original brake lines when I got it so it seems unlikely they would have ignored that but put in the effort to pull the valve cover and swap in overly thick shims.
    2. Is the camshaft condition a major issue? Can I continue to use as is or is it important to replace or polish the pitted lobes before doing any more riding?
    Unfortunately I can't comment on any changed performance qualities of the bike that could be symptomatic of these observations. As I say it's the first I've owned, so I have no point of comparison to notice unusual performance.
    Any information or resources to help me interpret these observations that would be very helpful. Thanks all.
  2. chacal
    You will be doing that for a while, as most owners of bikea do absolutely zero required or preventative maintenance. So check everything that should have been done in the first 15,000-km and do those.
    Common, normal, and expected issue when previous owners never do any required maintenance. Valve clearances are critical to proper operation and are part of any tune-up procedure. Valves are "slammed" shut by the dual coil springs on each valve, and as the valve rim slams into the valve seat in the cylinder head, it slightly "crushes" the valve seat and thus moves the entire valve further "up" into the head......towards the shim bucket/shim and thus closes the gap between the top of the shim and the cam lobe.....and therefore the clearances close up.
    "Tight" clearances are especially a problem on the exhaust valves, as the reduced cam lobe-to-valve shim clearance allows the valve to open sooner and close later than intended, which means that the valve doesn't get as much "seat time" on the valve seat inside the cylinder head.......and that "seat time" bleeds off heat from the hot valve into the head, thus cooling the valve face to a normal operating temperature. Lack of seat time results in burned valves and then the head has to come off and the valves repaired or replaced, etc. Even if the valve faces don't burn, the change in the valve opening and closing times (due to the reduced shim clearances) will reduce engine power.
    Cam lobes: that looks ugly, I've never seen that before. Debris got in there (did the previous owners ever change the oil? Probably not.......) or loss/lack of oil pressure. Are the SHIMS that were in contact with that (those) lobes also scarred like that?
    At the very least, I would try and polish the lobes (and then remove ALL the sanding debris that is created) to see if that condition can be at least somewhat remedied. Be aware that if the shims you removed from those lobe positions are also injured on their top surface, then replacement shims may suffer the same fate. Valve shims are surface-hardened on the first few atoms depth of their faces to withstand the extreme pressures between the lobes and the shim face.....and if that surface hardening is wiped off due to the cam lobe condition, then it will eat the shim pretty quickly and spread fine metal debris throughout the engine, which will then eat up cam and crank bearings, pistons/rings, etc.
    It sound like you've done a lot of the basic services that you need to do, just remember that there may be a number of other hand-grenades lurking within the bike, as people who don't do proper scheduled maintenance also tend to treat their bikes poorly in all other respects, too.
    https://www.xjbikes.com/forums/threads/tech-topic-the-real-costs-of-maintenance.14581/
  3. Rook_Defence
    Canada
    Thanks for the insights. I haven't gotten a good look at the shim under that lobe, but I'll be examining it soon.
    I'm wondering if the bike sat for long enough that oil drained away from that lobe and it stayed dry long enough to pick up a little surface rust. I've got wet/dry sandpaper on hand from 800 to 2000 grit so I'll give that a try this evening.
  4. Dan Gardner
    Minneapolis, MN
    I guess the rust theory would make sense since it doesn’t really look like wear on the lobes.
    Of course if I were you I would prefer to replace them. But I have spares, so I understand if you don’t want to go down that road. If it didn’t cost so much to ship to Canada these days I’d send you a set.
    edit- sorry, my collection of minty junk includes 650/750 cams, not 550s
  5. Rook_Defence
    Canada
    I appreciate the thought all the same.
    I've been toying with the idea of replacement, and my reservation is not related to cost, so much as by the possibility that I might spend a couple weeks waiting on the tools to validate a used camshaft, and then go through the process of purchasing and inspecting one, only to find that it's out of spec and I need another one.
    I've recently been trying to repair a printer with a defective print head, and having ordered two "new" print heads which turned out to be used and broken, the wait time between repair attempts gets old quicker than the expenditure does.
  6. Rayzerman
    Rayzerman Member
    Ontario Canada
    If it were me, I'd hesitate to "sand" the cam lobes with anything coarser than 2000 grit to start. May remove whatever that contamination is, but you really don't want to remove any real amount of material off cam lobes. As suggested look at the mating shim to see what shape it's in. I don't think you need to go get new cams....... perhaps even try a metal polish first.
    Absolutely change the out of spec valve clearances, and if you can get them all uniform across the board, the bike will run smoother. You'll need to do a good carb sync afterwards.
    cds1984 likes this.
  7. Rook_Defence
    Canada
    Yeah, it's definitely a light pitting so the "frosted" sections are actually sitting below the mirror sections, rather than being proud of the surrounding surface. Inadvertently altering the cam profile is definitely something I want to avoid.
    Are you suggesting a light polish with 2000 grit or higher, and then just run it as-is, as long as it's not eating the shim as chacal had pointed out as a potential issue?
  8. Rayzerman
    Rayzerman Member
    Ontario Canada
    If it were raised, I'd say more risk of eating the shim, however I'm not sure if the shims actually rotate on these, which would mean more uniform wear. If it is below the surface, I wouldn't do anything.... and shim wear will take forever, so I wouldn't sweat that too much. The only way you're going to know anything is to ride it for a year or some considerable mileage, pull a shim or two and see what's happening.... I think I'd ride more worry less. Just my opinion.
  9. Rook_Defence
    Canada
    The fact that the pitting sits below the mirrored surfaces and so should not contact the shims was on my mind too. It's not too much of a chore to check the shim more regularly and take action as needed. The tool for depressing the shim buckets arrived yesterday so I'll be able to examine the shim soon and see if there are any concerning signs. Thanks for the input.
  10. ScottFree
    ScottFree Active Member
    Northern Ill-Annoy
    Found this thread in a search. I noticed the same thing when I did a valve check on my 1980 Maxim 650 today. This bike was ridden about 7000 miles before 1996, then sat in a friend's garage without being turned over until 2023, when I inherited it and decided to get it running. It's now at 14,000 miles. This is what the #2 intake cam lobe looked like today:
    This one is probably the ugliest of the five that are not shiny and new-looking. Dragging a fingernail across the lobe does confirm that these are pits, not ridges. I suspect they are the result of corrosion during the almost 30 years the bike sat without being turned over. I pulled a shim to see if it was being chewed up by the cam, and saw no signs of wear. I have also confirmed that the buckets on the 650 motor do rotate, by observing how the notch in the buckets moves as I turn the engine during the valve check.
    For now, my plan is to ride it. I saved pictures in my maintenance log file and will see if the pitting gets any worse after another thousand miles or so.
  11. Rook_Defence
    Canada
    Much obliged for the pics, it's helpful to see a comparison of a similar situation.
    I reached a similar conclusion in the end. Changed over my shims, and the shims that came out showed no signs of unusual wear, so I didn't worry too much about it.
    I didn't get much riding in this year, but next year, after I hit maybe 1000 or 2000 km since the shims were replaced, I'll pull the ones from the dodgy lobes and check visually and with micrometer. If everything looks alright, I'll assume I'm fine to return to standard shim maintenance intervals.
  12. ScottFree
    Northern Ill-Annoy
    If you've got a set of minty junk 650 cams, I'd be interested...
  13. Dan Gardner
    Minneapolis, MN
    Let me dig around and I’ll send you a direct message
  14. ScottFree
    Northern Ill-Annoy
    Last week I stopped by my local shop, a place I've been dealing with for close to 30 years that repairs just about everything (including Japanese antiques) and sells Benelli, Benda, CF Moto, Royal Enfield, Ural, Zero, and still has their Victory sign over the door. I asked if they might know where I could get cams for my XJ. One of the mechanics said he used to have a few sets around but not anymore. Then they looked at my pictures. The guy said, yeah, he's seen that on a fair number of XJ and XS series bikes; not exactly a "they all do it" situation but far from uncommon. And he said that while he's seen quite a number of XJs with pitted cams, he's never seen one where the pitting turned into a problem. They'd come in for service, he'd note pitting on the cam lobes, they'd come back for the next service and the pitting hadn't changed... Now, this is one mechanic's experience, but the guy apparently saw a fair number of bikes. So... I am less concerned. I have put very nearly a thousand miles on the bike since photographing the cams. Another thousand or so and I will have another look and compare photos.
