Xj900 electrical issue
Discussion in 'XJ Technical Chat' started by MrSeca, Nov 25, 2026 at 4:55 PM.
  1. MrSeca
    MrSeca Active Member
    Oakland, CA
    Brake lights, neutral light, tachometer, horn, and signal lights all stopped working.
    The signal lights have been giving me issues for the past year before everything else.
    Sometimes the neural light will flicker while the bike is idling but will turn off after attempting to use the signal indicator.
    Im getting 12.6 volts at the fuse box which I upgraded to blade style about 5 years ago.
    Checked several brown wires for voltage and all check out.
    Opened up the left hand signal switch and cleansed up the ground wire.
    Bike starts and runs great. Any idea what I might be missing?
  2. Rooster53
    North, FL
    For everything to be dead I would be looking at the output of the fuse box since you verified 12V is there.
    First, is the signal fuse outputting 12V? If so, did you splice any wires or use just crimp connections when you added the fuse box - make sure those are good if you did either.
    The harness will have a splices also where all the smaller wires will connect to the larger wire or split into branch circuits, let's hope you don't have to go there.
    MrSeca likes this.
