81 maxim idle?
Discussion in 'XJ Technical Chat' started by LittleR640, Mar 11, 2008.
  1. LittleR640
    LittleR640 New Member
    Gettysburg,PA
    My 81 maxim 550 starts up fine and runs great until i take the choke off. When i take the choke off the idle drops real low and it sounds like the engine is struggling to run until it dies. I think that my idle is set too low. Just wondering if anyone knows what the idle should be set at, if that is the problem.
  2. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    1050 RPM. Try to turn it up and see if that is all it needs. Should it develope a hanging idle which means it idles high and comes back down slowly then the idle is too high and a carb cleaning is needed.
  3. MiCarl
    Idle spec on the 550s is 1200rpm.
  4. blackjack550
    blackjack550 Member
    san pedro california
    i set mine at 1300 but i have a question for u does your bike idle low when warming up with the choke on but when you hit the gas it jumps up to whereits supposed to?
  5. LittleR640
    Gettysburg,PA
    no it idles fine when i have the choke on it. once i turn it off it idles at about 600-700 rpm and just seems like its having trouble to keep running. also the lights pulse with the engine when it idles. Ill work on it and post an update. Thanks guys for all your help.
  6. chacal
    Little...your idle speed should be around 1100 rpm. You can adjust the idle speed via the large screw with the big thumbscrew head that exits between the two center carbs, facing the rear of the bike.
  7. LittleR640
    Gettysburg,PA
    well, that seemed to fix all my problems. thanks again for you guys' help.
