Recent acquisition
Discussion in 'XJ Modifications' started by xdarrickx, Mar 16, 2008.
  1. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    I just recently acquired a 1982 xj750j
    Here is a picture with the tank and seat removed. My plans are to chop it, hard tail it, and bob it a little. It's going to be a mix rat/bobber type thing. Should be awesome when done. Acquired this bike for a bag of fertilizer, sat next to his garage for a number of years, cleaned the carbs and it fired right up very strong runner.
  2. danno
    danno Member
    Union Springs,New York
    Nice score! But it is a 650 Maxim.At least the pipes,forks,grabrail,exhaust hangers and taillight are.But I wouldn't complain,for a bag of fertilizer! Tell the guy you got it from that I have a chicken that I would trade even up for an R-1! Great deal,and welcome to the site!
  3. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    The side cover says it's a 650 but the insurance card in it says xj750j.... so i dunno?
  4. chacal
    It appears to be an XJ650, it has the 650 style gauges and only a single disc brake, that means it's either an XJ550 Maxim (chain drive) or an XJ650 (shaft drive).
    Here's the VIN breakdown for the bikes. These 3-character codes are printed on the decal on the LEFT side of the steering neck, stamped into the steering neck on the RIGHT side, and also appear on the right rear of the engine case on a flat machined pad, just behind the clutch cover. Of course, it will also be on the title, as part of the entire VIN number, but will be preceded by the manufacturer ID Code (JYA), so the first part of the title VIN will read "JYAxxx" where "xxx" is one of the codes below:
    XJ550 Maxim:
    1981- 83: 5K5 (usa) or 5K6 (canada)
    XJ650 Maxim:
    1982-83 5N8 (usa) or 5N9 (canada)
    XJ750 Maxim:
    1982: 15R (usa) or 15T (canada)
    1983: 22R (usa)
  5. MiCarl
    Grab rail isn't right for a 550.
    550 has slash tip exhausts.
    I think I can make out the pinion housing.
    Verdict: 650
  6. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I may be interested in the seat. PM me if you still have it.
  7. Marko
    Marko Member
    Upstate, NY USA
    My paperwork had the serial number and "750 Maximum" I checked the numbers and everything and it turns out that its a 650 Maxim. Loved the deal I got from the guy who had no clue, wasn't too happy with the work needed to undo aforementioned guy's cluelessness. I thought about hard-tailing mine as well, but I am going to leave it stock-ish. I am going to chop my Suzuki once I get my hands on a garage that's not over an hour's drive away :p
  8. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    I'm going to check the numbers when i get to the shop tomorrow. i'm doing all of this where I work so it will make it real easy. I will also post progress pics and anything from the bike for sale. As of right now I have a stock air box, the seat (pm sent), Rear fender, grab bar, and sissy bar, looks to be stock handle bars. i'm also thinking of ditching the stock cluster pod and all of the controls... still up in the air about that.
  9. Marko
    Marko Member
    Upstate, NY USA
    Pm'ed you about the sissy-bar.
  10. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    Also the tail lamp, and all turn signals are for sale as well. and the front fender. Anyon know where I can find out or how I can do a dual front disc? And know of any other gas tanks that will fit? Also i'm looking for a 4-1 exhaust head pipes and collector, don't need the muffler or anything after the collector.
  11. Marko
    Marko Member
    Upstate, NY USA
    I believe a 750 XJ tank with fit the 650's with no problem. Also, if your bike has a single brake in front its probably a 650, in which case you can change it out with the 750 front assembly, but you'll also need the master cylinder. I believe this is the case, but don't take it as gospel.
  12. chacal
    Marko is exactly correct in his recommendations, although I'd add that the front end assembly needs to be off of a 750 Maxim, NOT a 750 Seca!
  13. Marko
    Marko Member
    Upstate, NY USA
    Woohoo!!! See, I'm learning.
    750 Tanks are in heavy competition, being that both guys with 750's and guys with 650's want them, so if you find one that's a good deal I'd jump on 'er p.d.q.
  14. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    turns out it is an 82 xj650 maxim
    after day 1 of build
      File size:
      78 KB
      4,843
  15. maximuschop
    maximuschop Member
    Indy
    WOW, I forgot how hideous stock maxim bars are 8O . Glad to see you chopping it. Keep us posted. I haven't been able to get mine in the garage yet. Two rhinos, my cbr, a golf cart, a bridgeport mill, lathe, drill press, saw, plus various cabinets, work benches, and toolboxes kind of "clutter" the work area.
  16. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    The stock bars are getting trashed for some drag bars should be arriving any day now...
    The ones that arrived were wrong so i made some.
  17. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    Update on things. I had a little time to mess with it. Got my drag bars put on, oil change, and stuff set up now it's tore apart and ready for paint.[​IMG]
  18. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    What do you guys think of what i've done so far?
  19. Marko
    Marko Member
    Upstate, NY USA
    Looks good. What material is the seat? Are going to stick with stock wheels or switch over to the spoked ones in the background? BTW, is that a 750 in the background? The only thing I don't like about my XJ is the lack of kickstart haha. But yeah, enough with the questions. Looking good!
  20. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    That seat is vinyl, i'm going to put on a spring white leather seat. Keeping the stock wheels and painting them. In the background is a '76 kz400. Guy at work got an itch after he saw mine... thats the next chop. I don't like the fact there is no kickstart and its shaft drive... but for what i gave for it and what i have invested i won't complain.
  21. Marko
    Marko Member
    Upstate, NY USA
    Heh, I should probably get some z's. I can't seem to tell one bike from another tonight. Can't wait to see the paint!
  22. dinoracer
    dinoracer Member
    Chattanooga, TN
    jeez and I thought my garage was cluttered. I'll take a Bridgeport mill and lathe anyday over my table saw and other woodworking junk. then again I have my fishing stuff, my woodworking junk, my beer making stuff, mmmmmmm beer!!!, my camping junk and the super seca 550 on a workbench..
    Wow just saw the pics and wow you have plenty of room for more bikes.. The ones you have are coming along nicely and should be great neck snappers for the coming summer.
  23. 07spacker
    07spacker Member
    Utah
  24. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    Here is the painted fender... first time painting a fender, it's exactly what i am looking for.
    Sorry for the crappy cell phone pic
  25. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    Some progress on the build today... installed speedo, set odometer to 666 permanently :lol: painted fuel tank, chopped kick stand to support bike, gotta find a way to keep the kick stand up though...
    here is the tank
    let me know what you think...
  26. Marko
    Marko Member
    Upstate, NY USA
    Love the paint scheme! Setting the the odometer to 666 is a great idea lol. Are you throwing a bunch of clear coats over the paint to protect it? What kind of paints are you using?(I've gotta paint mu Suzuki lol)
  27. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    That's right, make it your own! Nothings better than chopping a bike. There's a certain satisfaction you get when you sit back and look at the progess. It's almost as fun as riding and good therapy for when there is a foot of snow on the ground outside.
    I didn't like the idea of customizing a bike with shaft drive either, but there are alot of ways to make it an exceptable candidate for chopping. I never thought I could get mine to look like I did until I took the plunge and did it. Old parts bikes are great for parts too. Mine has Kawasakii, Suzuki, and Harley parts on it.
    I've got to do something with my paint now. I don't like what I did last winter anymore and it needs a face lift now!
  28. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    Here is the bike together, after a nice smokey burn out. Sorry didn't get a pic of the burn out...
    Rode it down the highway bike felt awesome, good power I am pleased... Pretty much done except waiting on my headlight tail light and seat....
  29. Marko
    Marko Member
    Upstate, NY USA
    Looks badass. Speaking of which, watch the bumps while you're waiting for your seat!
  30. maximuschop
    maximuschop Member
    Indy
    Looks good, keep us posted! Are you gonna do some custom pipes?
  31. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    Here's an update. I got the wiring on the bike completed, ignition switch is moved. Headlight taillight and license light are all wired and functional.
    I do plan on doing some custom pipes. Both sided 2 into 1 then both will turn out staggering onthe right hand side.
    Let me know what you think
  32. earz_cd
    earz_cd Member
    Jefferson city, MO
    Looking good. Where did you get the taillight? Is it individual leds or a strip?
    I'm getting ready to start down this same path with my '82 650
  33. PainterD
    Ah, looking good! Ya gotta love those LEDs, they are sweet looking. I like what you did with the tailight. How bright/noticable is it in bright sunlight? That would be my only concern with that strip of lights. Keep us posted on your progress. PD
  34. BakoMack
    BakoMack Member
    Bakersfield, CA
    I love the brake light idea, im trying to get my hands on another xj front fender, im gonna weld it to the swing arm infront of the tire so it has a close tolerance to the tire and will actually move with the tire when the ride height is adjusted
  35. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    I got the led strip off of ebay already wired up for a dual intensity for a brake and running light. They are surprisingly bright.
  36. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    95% complete just need exhaust and tires
    what do you think?
  37. PainterD
    Looks wicked from here! Nothing better than having one of a kind and being able to enjoy it. Good job xderrickx!!
  38. CharlesCollins
    CharlesCollins Member
    Milwaukee, WI
    I'm diggin' that white seat. I think seat covers other than the standard black can really make a bike distinctive! Nice work!
    -c
  39. RickCoMatic
    That's got some decidedly "Old School" looks to it ... I must say!
    Retro!
    Although I am one to view such projects, (deviating from Showroom) as sacrilegious ... I must tip my cap to you on creating such a unique bike.
    Nice work.
  40. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    Thanks for all of the feedback guys...
    I was going for an old school kind of bobber feel to it... I kind of want to do a mono leaf spring front end on it.
  41. oby_2
    oby_2 Member
    Sydney, Australia
    XdarrickX,
    Great work. Looks fantastic for the short time you have spent on it. Makes me feel L A Z Y...
    Where did you get the rear shocks? Did they lower the bike much? I had a quick review of postings and missed it if you mentioned it before.
    oby
  42. earz_cd
    earz_cd Member
    Jefferson city, MO
    He made it a hardtail by using a solid strut. I'm not sure how much he dropped it though.
  43. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    Thats actually the factory strut, I took the spring off and welded it in the down position. I dunno how much of a drop either. Maybe 3-4" ?
  44. maximuschop
    maximuschop Member
    Indy
    Looking good! Keep us posted on how she turns out. If you want old school def. go with the whitewalls :D
  45. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    Well I brought her home today from the shop. Not much has changed, did some re-wiring and aimed the headlight and gave her a bath. Here she is at home, nice shiney day, waiting on title to come in the mail so I can get a tag and go for some long hauls.
    Also a picture of my sweet helmet to go along with it.
  46. chacal
    Cool helmet!
  47. RickCoMatic
    If you have the bike running really well; I'm sure there are more than a few that would be interested in how you Jetted the Carbs for that set-up.
    It would be nice of you to outline the Jetting and other Mods you did for those who are going down the same path; putting-on Pods and abandoning the airbox.
  48. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    Mods ----
    Stock rear fender relocating and holes shaved
    Drag bars
    Yamaha Raptor master cylinder
    LED stop and tail lamp
    rear section of frame cut off
    exhaust cut off behind pegs
    modified air box to hold wiring and ignition switch
    shaved tank emblems
    remote kick stand
    lowered rear by removing springs and welding the shock down
    As far as the jetting I haven't touched the carbs except to clean them. It runs amazing and keeps up with my buddies CB750 no problem.
    I wanted to spend minimal money on this project. All together I have less than $400 in the entire bike. White walls to come soon and that will boost total to just over $600. It's going to be at the Smoke Out in North Carolina in June.
  49. kevineleven
    kevineleven Member
    Columbus, Ohio
    I'll see you there.
  50. xdarrickx
    xdarrickx Member
    Oklahoma City, OK
    The bike is going in the back of the pick up until I get back to Dayton, OH and then a group of us are riding from Dayton to the show on Thursday before. Using the truck and trailer as a chase truck. I'm pretty excited about it.
