chain drive conversion
Discussion in 'XJ Modifications' started by luney2nz, Mar 22, 2008.
  1. luney2nz
    luney2nz New Member
    Canada
    has anyone seen or done a chain drive conversion on a maxim x before?
  2. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    I just have to ask.....
    Why go to a chain drive?
    Shaft drive doesn't require as much maintenance.
  3. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    The chain drive conversion is not an option, unless you are ready to do alot of machining alot of parts to convert the shaft output to a sprocket. So I guess anything is possible if your willing to spend the time and money. It would be nice to be able to extend the swing arm back some and mess with sprocket sizes for higher gear ratios.
  4. luney2nz
    luney2nz New Member
    Canada
    thanks for the info- the plan is to extend the swing arm about 4-5 inches. I would also like to go with a rear disc brake set up. I'm going for the street fighter look, I've got an inverted front end from a newer kawi and right now i'm working on the rear fender, dropping a 97 R1 tail light in it and doing some 3-d biomech around it.
  5. maximuschop
    maximuschop Member
    Indy
    You can extend a driveshaft, can't you?
  6. leaningleft
    leaningleft Member
    Cobourg,Ontario,Canada
    Mind if i cut in here with a drive chain question.I'm been looking at replacing the master link on my chain as it's looking a bit rough from being hammered on and off a few times.Now i'd rather look at just replacing the whole chain.My question is.chain size is 530 is this and the number of links all i need to order a new chain.
  7. leaningleft
    leaningleft Member
    luney2nz I think if i'd go through all that tooling i'd look to go belt drive.as a possable
  8. luney2nz
    luney2nz New Member
    Canada
    yes extending the drive shaft is easy but it still leaves me with drum brakes
  9. rpgoerlich
    rpgoerlich Member
    Katy, Tx
  10. RickCoMatic
    Rather than dreaming-up some way to convert a Shaft Drive XJ to Chain Drive.
    (It aint gonna happen unless you own a bank and a machine shop; too)
    Why don't you just look around for and FJ Engine.
    The FJ's are Chain Drive.
    The FJ's are also perfect for modifying into Street Fighters!
  11. 85700x
    85700x New Member
    how does the fj engine compare to the 85 700 x engin?
  12. poprider
    poprider Member
    Seattle, WA
    About 50-60 more horsepower.
  13. bigfitz52
    Basically yes but there is a bit more to it.
    Start a new thread.
  14. scarpscape
    scarpscape New Member
    What?!!! Are you on glue? I hope you were joking. Double the hp. is asking a bit much.(sarcasm)Get your facts straight.
