have to bump start
Discussion in 'XJ Technical Chat' started by blackjack550, Mar 25, 2008.
  1. blackjack550
    blackjack550 Member
    san pedro california
    i have to bump start my bike everyday, my starter will turn over with a car batter but the bike battery only clicks the selonoid and only turns it over once in a while but not long enough to start it.
  2. 07spacker
    07spacker Member
    Utah
    sounds like you might have a loose connection to your battery
  3. MiCarl
    Or a battery that needs to be replaced.
  4. turbobike
    turbobike Member
    Grand Island, Nebraska
    perhaps a bad ground somewhere, or bad lead cable to the starter.
    it sounds like your current system needs more amps to get things turning.
    bad battery, bad wires, bad ground points, bad lead connection points will all attribute to lose of amps.
    they also add to resistance, lowing the overall voltage.
  5. thefox
    thefox Member
    Central NY (@ college in W. PA)
    I agree, a dead cell or two in your battery will cause this. Don't forget that motorcycle batteries don't last forever, most should be replaced every few years.
  6. Jon81550Maxim
    Jon81550Maxim Member
    N.Ontario
    It may also be a corroded starter button connection. the contacts might need cleaning. i took mine apart and re-soldered the wire to the contact......along with every other @#$%@#$ contact. It's dosen't seem like it's the same bike. Turns over like a race car. :twisted:
    I used dielectric grease on every connection. It's non conductive and dosen't allow arcing.
  7. blackjack550
    blackjack550 Member
    tanx fellas its a new battery that puts out 13 volts so im going to double check all of the connections.
