remove the stoplamp switch
Discussion in 'XJ Technical Chat' started by Jzap99, Mar 26, 2008.
  1. Jzap99
    Jzap99 Member
    Mississippi
    I am trying to take out the stoplamp switch from the brake lever and can't seem to figure out how to get the switch out I have read the manual but I cant find the pin to push in, help please
  2. chacal
    there's a small holes in the m/c housing (I believe it face forward, towards the front of the bike) and you push in this hole with the tip of a pen, screwdriver, etc. and that releases a toothed expansion "clip" on the brake light switch, which allows you (at the same time you're depressing this clip) to pull "out" on the brake light switch/harness.
  3. Jzap99
    Jzap99 Member
    Mississippi
    I got it out thanks man.
