Handlebar riser for Xj750
Discussion in 'XJ Modifications' started by muttly, Mar 29, 2008.
  1. muttly
    muttly New Member
    Minneapolis
    Hey everyone. I replaced the stock handlebars on my XJ750 with some drag bars. Of course now the choke lever hits the tank when I turn to the left. I'm wondering if I could put some risers on it to elevate the bars a bit more above the tank. Does anyone have experience with this? Where can I buy them? Did you have to adjust the guage cluster to mount the risers? Any help would be much appreciated!
    Thanks,
    Muttly
  2. Stinky
    Stinky Member
    Flagstaff, Arizona
    I had a setup last year with drag bars and 6" dogbone risers. No problems but then again, I took my gauges off.
  3. southpaw
    southpaw Member
    new york
    I am currently doing about the same thing. I have ordered riser that are for a Virago. should have them this week I will take some pictures if they work out and let you know
  4. muttly
    muttly New Member
    Minneapolis
    Thanks for the responses guys.
    Southpaw--can you tell me where you ordered your risers from?? Pictures would be great. My biggest concern is the gauge cluster getting in the way of the riser.
    Muttly
  5. southpaw
    southpaw Member
    new york
    Muttly I ordered the risers from scootworks .com. I am 99% sure they will fit a xj. I dont belive the gages will be a problem because they rise 2" and pull back 1 3/4" There are really good pictures of them at the web site. Sorry I dont know how to attach links Expecting mine any day now As soon as I get them I will mock up the front end and get you pictures
  6. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Just about any 7/8" risers will work, if you have some type of short risers on there already. Most of them bolt thru the upper tree with bolts, then you mount your bars on top of them.
    I didn't want to go out and find a pair, so I just cut the top off an old pair of risers I had from a Maxim and welded 4" pieces of tubing under them. Then to mount them on the upper tree, I welded 5/16" nuts inside the tubing to bolt them on. They ended up lworking perfect and are plenty strong (I tried to bend or break them to make sure they were strong enough) You will need 4"-6" depending how high you want your bars.
    You can't see them very well on this photo (they're painted black) but you can see the bottom of them just below my cigarette lighter. You can just make out the washers where they are bolted to the upper tree. You can see how high they raised my bars too. PD
  7. BakoMack
    BakoMack Member
    Bakersfield, CA
    any word on those risers? I have a set of new bars on the way and I was wanting some risers, plz inform us how they fit as I might be ordering a set
  8. Shim
    Shim New Member
    Pink, Oklahoma
    Hey if those virago risers work i would to know i have had many dragbar issues with my 1980 650xj
  9. southpaw
    southpaw Member
    new york
    Hey guys I got an e-mail from scoot works the other day the risers are on back order. Probaly wont see them until next week
  10. BakoMack
    BakoMack Member
    Bakersfield, CA
    well thats a no bueno, I was wanting to order some :cry:
  11. southpaw
    southpaw Member
    new york
    OK guys the risers came in same day I posted the last thread. Let me tell you they are sweet!!. They come with adapters that fit perfectly on the xj's . I was worried that there would be clearance issue with the ignition but its not even close. they look awesome will try to get pictures later today
  12. southpaw
    southpaw Member
    new york
    trying to get you pics
  13. southpaw
    southpaw Member
    new york
    trying to put them hear there are two pics in my gallery if this doesnt work
