Gas Cap swap/mod??
Discussion in 'XJ Modifications' started by regulator, Apr 10, 2008.
  1. regulator
    regulator Member
    Ankeny, IA & Brooklyn Center, MN
    Hey all,
    I am wondering if any of you have done a gas cap modification and if so how? I am wanting to remove the locking style cap on my maxim750 and replace it with a old style screw on cap, but I have no Idea how to go about doing this. Any knowledge shared on this idea would be greatly appreciated. If that idea is impossible to do, I was possibly thing of a way to "shave" the stock cap down (or replace with??) to make it sit more flush with the rest of the tank.
  2. ronnie
    ronnie Member
    Searcy, Arkansas
    I replaced the locking gas cap on one of my Seca 900`s with the flush mount cap off of a Seca II. My friend does body work and he cut enough metal around both filler necks and welded it in place.
  3. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    With the way the filler necks are on these bikes, I would say you only option is to cut a piece out and weld in the filler neck from another tank with the cap style you want.
  4. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Yes, it looks tome like a welding job to re-fit a different style cap on these tanks. And you must remember these are vented gas caps on the XJs. Some are not vented and have a small hose that comes off the tanks to give it air to replace the gas used.
  5. regulator
    regulator Member
    thanks for the info guys
