Painting chromed parts
Discussion in 'XJ Technical Chat' started by TSizemore3, Apr 16, 2008.
  1. TSizemore3
    TSizemore3 Member
    Florida
    Any suggestions on prepping chromed parts like the gas cap and handlebars for painting? I've seen something called an adheasion promoter but wonder how well it sticks. Also the chrome exhaust pipes are a bit skinned up from the PO laying it down. Is there a high temp gloss paint that will work for chromed surfaces?
  2. Altus
    Altus Active Member
    London, Ontario
    Paint won't stick well to chromed surfaces - period. It WILL peel. Sand it rough and use a good quality metal primer and it'll work for a while.
    If you want to do it right, you need to get the chrome stripped off then prime & paint (or even better - powdercoat).
  3. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Sand it down well, the use a 'self etching primer' then paint it, thats about the best your going to get without going all out and fully stripping the chrome from the parts
  4. Jim_Vess
    Jim_Vess Member
    Lafayette, CO
  5. hbalir
    hbalir New Member
    I'm in the body shop business and you can get paint to stick to chrome, the key is you have to sand it with really coarse paper, like 80 grit, use a good metal etching primer, then primer surfacer. I blacked out the chrome oh my old bmw here. No probs, again you have to rough it up with coarse paper.
    I've been thinking of painting my gas cap too, if I do I'll show you how I did it.
  6. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    Hydrochloric acid ( muriatic acid) will strip the chrome.
    Then etching primer then paint.
    Oh yeah rinse well with water and a little baking sode to neutralize the acid.
  7. TSizemore3
    TSizemore3 Member
    Florida
    Thanks for all the replies. It's given me some ideas.
  8. jeff4995
    jeff4995 Member
    Alberta,Canada
    I sandblasted my chrome parts before painting.
  9. luna3
    luna3 Member
    Dorloo, NY.
    Like Jeff I sandblasted my fenders then used epoxy primer under lacquer. That was 3 years ago and no problems.
  10. mac11
    mac11 Member
    Outside Chicago
    details on the acid application? wipe on/off? submerge part in acid bath? other?
