Basics for XJ owners
Discussion in 'XJ Technical Chat' started by gcrick, Apr 18, 2008.
  1. gcrick
    gcrick Member
    near Austin, Texas
    Collecting a list of XJBikes members' basic tips for new XJ owners:
    ___________________________________________________________
    REFERENCE INFO...
    XJ Bikes CD
    Aftermarket Service Manual (e.g. Haynes)
    Factory Service Manual for your model
    Yamaha owner's manual
    www.XJbikes.com forums, of course
    USEFUL TOOLS...
    basic metric and hand tools
    normal garage stuff (batty. charger, etc.)
    JIS style screwdriver set
    electric multimeter
    good quality torque wrench
    good hand-held impact driver (1/2" Drive)
    portable electric air compressor
    Colortune plug
    manometer (homemade is fine)
    2 hardwood hammer handles (to pry carbs, apply impact)
    plastic/rubber pan - kitty litter box size
    metal carb rack - (e.g. grill from a toaster oven, appliance)
    rubber eye/ear squeeze bulb syringe
    bag of long, white pipe cleaners (carb and detailing work)
    automotive style electrical test light
    Road Tool Kit (discussed in separate thread)
    compression tester
    blowby tester
    length of fiberglass driveway marker (YICS and probing)
    medium sized funnel
    3 feet of 1/4" vinyl or rubber hose/tubing
    brake bleeder (usable by one person alone)
    long "Snake" flex cable parts retriever
    long magnetic parts retriever/probe
    THINGS TO DO... (what every XJer should check/improve/do)
    normal MC operation & safety checks (tires, clean tank, etc.)
    wear gloves, ankle-high shoes, and esp. good quality helmet
    MC riding safety course, beginners or refresher
    Maintenance:
    top up battery w/distilled water, charge fully
    lubricate all cables, lever pivots
    take up excess rear brake slack
    lube steering head bearing, or upgrade to tapered
    check, clean, repair, synch, maintain carburetors
    keep carbs clean - line filter, safe cleaner in gas, etc.
    check condition and balance wheels, tires
    check and adjust valve clearances *important
    add inline fuel filter
    check, repair, replace fuel petcock
    replace old fuse block w/modern
    check, repair, replace alternator brushes
    clean, seal all electrical connectors/connections
    upgrade carb bowl drain screws to allen-head type
    eliminate Warning sensor/bulb (if applicable)
    XJ UPGRADES... (not required but recommended)
    Better Headlight, Tail/Brake/Turn Lights (details on threads)
    Spin-On oil filter
    Air Filter - UNI foam, etc.
    THINGS NOT TO DO...
    don't try to open middle gear drain plug - unnecessary, risky
    don't weld on the bike without the necessary precautions
    don't put "energy saving" motor oil in - can ruin the clutch
    don't just pull the plug boots, then crank the engine (may hurt coils)
    don't use resistor type plugs
    don't crank if a petcock, line or carb is leaking on your engine <fire>
    Special Thanks to: Robert, Rick, A.Fault, Time2Ride, Chacal, Ritz, labelleb, MGM, and others
  2. Robert
    I don't want to steal Rick's thunder but Alternator Brushes should be in your list of tasks.
  3. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    G,
    The manual(haynes is what I have) covers all bikes. The factory manual is specific to YOUR bike. Kinda nice, my dog ate mine(literally) :(
    From what I understand, the colortune works best WITHOUT an adapter. I think someone else, CHACAL, should comment though....
    Dont worry, I WILL help you break in that Colortune :)
  4. TIMEtoRIDE
    The quality helmet - gloves - shoes that cover the ankle, for riders who haven't been on a bike in a while, and a safety course.
    Homemade Manometer and the tune-up skills
    Lubricate all cables, lever pivots, take up some of that rear brake slack!
    lube steering head bearing, or upgrade to tapered set-up.(Chacal-PM)
    Balance your own tires at home.
    Remove the WARNING bulb.
  5. chacal
    Also, get yourself some JIS style screwdrivers. I will make your life so much simpler:
    HCP5904 JIS Standards SCREWDRIVER SET. Japanese phillips drive screws have sharper corners than regular phillips screwdrivers so they won't turn out under heavy torque. In order to take advantage of this feature, and to avoid stripping out the JIS screw heads by using US-standard phillips screwdrivers, it's a good idea to invest in a set of quality JIS-standard screwdrivers. This set of 4 contains one each of #1, #2, #3, and #4 sized-tip screwdrivers, and this range of sizes will handle everything down to an M3 sized screw (that's tiny, like the size of the petcock faceplate mounting screws) all the way up to screws bigger than anything I've seen used on these bikes. They all feature sturdy plastic handles, chrome plated steel shafts, and come in a handy vinyl storage pouch.
    $ 34.00
    Do not use the 14-to-12mm adapter if it can be avoided.....you'll get false readings, which defeats the purpose of using the colortune plug:
    j5b) Colotune Spark Plug 14-to-12mm ADAPTER. Available for those who have bikes than use both 12mm and 14mm plugs, but only want to buy one Colortune Plug and use it on both engines. This adapter allows the use of a 14mm plug in a 12mm spark plug hole. NOTE: not for use on cylinders under 180cc displacement (720cc or smaller on a 4-cylinder motor) as the extra volume that this adapter increases the combustion chamber volume, which in turn decreases the effective compression ratio of the engine---thus resulting in an unreliable reading from the plug. Only really useful for XJ750-X owners, as they are the only XJ-series bikes that have 12mm plugs AND have a cylinder displacement greater than 180cc.
    HCP6496 Colotune plug 14mm-to-12mm ADAPTER.
    $ 16.95
  6. gcrick
    gcrick Member
    near Austin, Texas
    Saddle up, then. Because the CenTex XJ family has another Colortune in hand. PM or email me to meet.
    Chacal, thanks for your advice on the adapter. I asked in case it would be of wider use by my bike mechanic buddy, since I was heading over there today to talk him into a sharing deal.
    Happy coincidence: when I got there he dug into a drawer, came up with a brand new 14mm Colortune in the box and said "here you go!" Seems another mechanic bought it for old multi-carb sports cars but gave it to my buddy unused. And his shop relies on vacuum gauges for carbs.
    So we got a Colortune and I saved some bucks I can now use to get stuff. [What do I need next, Chacal?]
  7. chacal
    Oh, that's easy!: Everything!
    Just be aware that the "older" automotive style colortunes had a problem when being used in bikes, due to the increased cylinder head temps on air-cooled bikes.....and if you leave those auto style colortunes in the head for too long, they "clear" window either goes opaque or cracks.
    So, in-and-out quickly when using a colortune is hte name of the game, and let is cool down just a bit in-between cylinder tests.........
  8. gcrick
    gcrick Member
    near Austin, Texas
    Thanks for the good advice, T2R.
    Do you happen to know a link for tips on balancing?
    Could you explain more re: the Warning bulb? I'm not clear on that.
    walked into that one, didn't I? :D Oookay then,... could you tell me (PM?) the next few items on the Everything list? :) Inline filter is in.
  9. Ritz
    Ritz New Member
    Midlands UK
    New fuse holders are pretty much top of the list.
  10. gcrick
    gcrick Member
    near Austin, Texas
    Replacing old 4 fuse block w/new blade fuse box, right? maybe 6 in case we ever want to add circuits?
    There aren't any other fuse holders to worry about, are there?
  11. chacal
    Hey gcrick, well, like you said at the top, the three sorest spots on these bikes are:
    - electrical system (meaning, upgrade the fusebox and check/replace the alternator brushes, clean and seal every last electrical connector/connection on the bike, a truly boring and tedious pain in the tailpipe, but, your life will be better and since it's a tedious kinda task, you can get as wasted as you like while doing it and still be pretty successful at the task. Just remember to disconnect the battery first!)
    - fuel system (fix/rebuild the carbs, fix/rebuild the petcock, and install an inline fuel filter)
    - oil system......not necessarily a problem, but the factory filter is small and a pain in the butt to get to.
    - check and adjust your valve clearances!!!!!!!!
    - upgrade the carb bowl drain screws to the allen-head style.
    - owner's manuals are nice to have for basic info, such as how to operate the controls, etc....that type of "user instructions" are not found in the "service manuals".....such as, you are ALWAYS supposed to "push in" on the turn signal switch after it returns to its central position.....that releases the internal spring and prevents you from bending it, etc.
    - But perhaps the most important things that an owner might want to have are the proper ways of THINKING about these older bikes:
    a) So, for heavens sake, everyone, PLEASE get a factory or aftermarket service manual for your bike (or both) and I know that this is kinda of a heresay, but READ AND FOLLOW THE FACTORY RECOMMENDATIONS AND INSTRUCTIONS. I realize that many people think that they know "better" than the company that designed, built, tested, and serviced the original bikes, but in most cases, following the factory advice and specs will put things exactly right. Once you have mastered the "factory way" of doing things, then sure, by all means you can use some tricks or shortcuts, but please try to learn and understand completely the "right" way to do things BEFORE you go to the "shortcut" methods!
    b) Realize that while these bikes are quite reliable, that just because their selling prices are "inexpensive" compared to the prices of new bikes does NOT mean that parts or service work is also going to be cheap! The rule of thumb in the vehicle world is annual service and maintenance costs are 10-20% of the vehicle price, and that is based upon the price of a NEW vehicle. Just because these bikes are 20+ years old does not mean you get to figure the annual maintenance costs based on the "used" prices! A comprable brand new 2208 versions of an XJ650 Maxim is about a $7,000 - 9,000 dollar vehicle, and therefore, you can assume about a $800 - $1500 annual maintenance/service costs (you save the labor costs if you do-it-yourself), EVERY YEAR. In some cases the maintenance costs will be even greater, given the age and previous up-keep of the particular machine.
    Failure to appreciate the reality of the above leads to incredible amounts of misunderstanding, neglect, and frustration, leading to ignoring the service or taking shortcuts, which starts the neglect>frustration cycle all over again..........
  12. chacal
    Correct!
    Much better choice. Especially if you want to get the most out of your stock or upgraded headlight, which means you need to add a set of headlight relays, the stock tiny wiring just barely cuts it on the stock haedlight, and certainly doesn't cut it for upgraded light.
    Oh yes there are, depending on the model:
    XJ700 and XJ1100 models use a small, inline glass fuse holder for the MAIN bike fuse.
    XJ650 Turbo, XJ750 Seca, and XJ750J (1982) models all use a 5A glass fuse inside a in-line fuse holder, up by the gauges area, for the computer dashboard system.
  13. labelleb
    labelleb Member
    Mckinney, TX
    I picked up some extra front lights. Set of 50 watt halogen round lights from Walmart for 29.99. Got "wire cables" with rubber backs from Home Depot for 1.25. Basically a metal saddle clamp with rubber that I can lock down and then bolt the lights right into. I'm still wiring them up but I'll post a picture when Im done. Not really necessary but the more light out in front the better I think.
  14. TIMEtoRIDE
    Balance tires- - remove axle then tire/rim. Get 2 cinder blocks, or 2 steel chairs, put axle back in, place between blocks, wiggle the axle a little. The heavy part goes down. Now go out and buy some weights.
    WARNING light- - If you don't know what this is, you're lucky!
    Apparently someone thought it would be cool to monitor the battery condition with a probe (that dissolves, maybe shortening battery life?)as well as other functions, and relentlessly flashes unless everything is perfect.
    Also those new to XJ ' s need a list of "THINGS NOT TO DO"
    middle gear drain plug- - don't go there!
    don't put "energy saving" motor oil in- ruins the clutch
    don't just pull all the plug boots, then crank the engine, this could damage the coils, sometimes.
    don't crank it If you have a leaky fuel valve, carbs or lines, and they are dripping on your Alternator, Starter and Exhaust. (fire!)
    don't do handlebar tassles or ride a dude.
    I'm sure there's lots more. . .
  15. chacal
    By far the most important of all.......
  16. RickCoMatic
    An Automotive Style Electrical Test Light.
    A MutiMeter
    A Compression Tester
    A Blowby Tester
    2 Hardwood Hammer Handles for Prying Carbs and Applying Impact
    A RubberMaid Kitty Litter Box
    A Grill from a Toaster Oven (Carbs)
    Rubber Eye and Ear Syringe
    A length of fiberglass driveway marker (YICS and Probing)
    A Good Torque wrench
    A Craftsman Hand-held Impact Driver 1/2" Drive
    A bag of long, white Pipe Cleaners (Carbs and Detailing)
    A medium sized funnel
    3 feet of 1/4" Vinyl Hose
    A One-Man Brake Bleeder
    and ...
    A long "Snake" retriever
    A long Magnetic Probe
    Portable Electric Compressor
  17. labelleb
    labelleb Member
    Mckinney, TX
    gcrick I see you're in Austin. If you ever get up to North Dallas for something drop me a note. We can talk bikes over a beer
  18. gcrick
    gcrick Member
    near Austin, Texas
    Sounds good! lived up there a couple of years during school (if you call South Oak Cliff living) married girl from Farmer's Branch.
    Wonder if we're getting enough Texans to start an informal XJ Texas chapter? Maybe all meet in Waco?... ride our bikes inside the Ranger Museum?... meet a nice Waco bail bondsman? ...or maybe not.
    Where you mounting the new lights on your bike?
  19. MGM8675309
    MGM8675309 Member
    Fort Worth, Texas
    I have no clue how hard it would be to remove the bulb, but i just hotwired mine. Sensor wire to a hot source cured the warning light.
    Don't EVEN wanna ask! 8O
    :lol: but ditto on both!
  20. MGM8675309
    MGM8675309 Member
    Fort Worth, Texas
    You guys should make plans to attend our N TX Carb Clinic when the time comes. Last year it was in September, it would be nice to have it earlier in the year so we all can get our bikes tuned up for the full riding season.
  21. gcrick
    gcrick Member
    near Austin, Texas
    Just give the word as soon as you know the date; the XJers from AU and NZ need plenty of lead time to make the trip.
    And I agree: earlier clinic = more riding days. wonder if we have enough XJs for a South/Central TX clinic?
    Or statewide? Or national? Or planetary? [Uh-oh, it's clearly time now to cap the carburetor cleaner.]
  22. labelleb
    labelleb Member
    Mckinney, TX
    I actually wanted to make the carb clinic in Sept but work interfered with my bike!!! I had been keeping an eye out for anything on it. Im ready just tell me when
  23. labelleb
    labelleb Member
    Mckinney, TX
    gcrick, I mounted them on the turn signal stays. I'm headin down to the garage this morning to finish wiring them up and I'll post a few pics of how I did it
  24. gcrick
    gcrick Member
    near Austin, Texas
    after several edits to add your input, the list of Basics I Need To Know (above) is coming together. One thing I'm still not clear on: Any air filter changes recommended for stock XJ reliability (not maximum performance)?
    Also, since I haven't read much to the contrary, I assume the stock exhaust system doesn't need modification for normal riding.
    thanks,
    gene
  25. chacal
    Air filter: about the only upgrade that I would consider is the UNI foam filter element, it can be washed and re-used indefinetly, flows as well or just slightly better than the stock paper element, which means no jetting changes are needed.
  26. gcrick
    gcrick Member
    near Austin, Texas
    thanks, Chacal. I've edited that info into the post beginning this thread.
  27. gcrick
    gcrick Member
    near Austin, Texas
    JIS Phillips
    recognizing good advice, I have been looking for JIS screwdriver bits.
    [CHACAL, didn't see any in your list(s). Let me know if I overlooked them.]
    Did find this tool site with #2, #1 and #0 bits. Think those JIS sizes would do all I need?
    gene
  28. labelleb
    labelleb Member
    Mckinney, TX
    OK now for my dumb question. Why the JIS? Why not just good old regular phillips?
  29. schmuckaholic
    California
    Re: JIS Phillips
    I don't think he has bits; rather, the entire screwdriver. A set of them, in fact.
    Chacal addresses this in his price list. No, I don't have a set. I'm tempted to get a set of those bits on the website -- wish they had the larger sizes, though.
    Quoting from Chacal's price list:
    Almost every screw on these bikes are "JIS" design screws, JIS standing for Japanese Industrial Standards, and both the depth and design on the phillips-head "slot" is different than typical US slots. In a nutshell, JIS screws (which can be easily identified by the small punched single "dot" on the screw head, in between two of the screw slots) have both deeper and "squarer" slots and thus can hold more torque than their rest-of-the-world counterparts. They also require a JIS screwdriver to take full advantage of, and to prevent rounding out the slots as typical phillips-slot screwdrivers will do. The more "rounded" edges of a standard phillips-head screwdriver cannot exert as much torque on the screw head (by design, actually) and will "cam-out" of the slots, taking some of the slot material with it unfortunately!
    $ 34.00
    There, Len. Saved you the trouble. :mrgreen:
  30. gcrick
    gcrick Member
    near Austin, Texas
    Others can give better answers but when I had a Kawa dealership we used JIS screwdrivers for them because the pitch seemed slightly different and we thought it reduced chances of stripped (tunneled) Phillips screwheads.
    Which, as we alllll know, can be a genuine pain.
  31. chacal
    Schmuck, you're my hero!
    GC, the #1 and #2 sizes are the most common on these bikes, anything smaller than that is really for working on computers, etc. and won't be useful. The #3 size can be used on some of the REALLY large screws. The #4 size is good for tanks and large industrial equipment.
  32. chacal
    PS.....and by "tanks" in the above posts, in relation to the #4 size screwdriver, I meant as in "military equipment" type tanks---the ones with machine guns and turrets and the like---not little ol' XJ fuel tanks!
  33. gcrick
    gcrick Member
    near Austin, Texas
    Schmuckaholic answered LBelle faster and better (above) while I was still looking up how to spell the big words, like screwdriver.
    Chacal, so you're confirming (remember I'm not the brightest bulb in the halogen module) that if I get your screwdriver set, as planned, and those #0,1,2 loose bits, I'm covered. Well, that works for me!
    Tanks a lot,
    gene
    PS. A reason I also want loose bits is not just for interchangeable and electric drivers but also because they'll fit a single handle in the new rider's mini-kit currently under development at the XJBikes.com R&D center. I've added the road kit to our growing 'XJ basics' list.)
  34. chacal
    You'll be more than covered!
  35. gcrick
    gcrick Member
    near Austin, Texas
    HERE'S MY OWN LIST (top of thread), COLLECTED FROM EXPERTS HERE...
  36. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Here is a tip for Phillips headed screws or any other screws. If you want extra gripping power use a touch of valve lapping compound on the tip of the screw driver. The abrasive will add friction and not let the driver slip.
