difficult time getting tank on the mounts
Discussion in 'XJ Technical Chat' started by Ltdave, Apr 20, 2008.
  1. Ltdave
    Ltdave Member
    whats the best lube to use on tank mounts so i can get the tank mounted without having to resort to hammering it forward?
    this is on the 750 seca...
  2. acergremlin
    acergremlin Member
    NE UK
    i just give mine a squirt of wd40, slides straight on.
  3. labelleb
    labelleb Member
    Mckinney, TX
    I just used some liquid wrench and it worked too. Of course that was after using the rubber mallet the first few times.....doh!
  4. Robert
    Smear of silicone grease will do as well.
  5. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Sil-Glyde works well.
  6. Ltdave
    Ltdave Member
    yeah i used a block of wood and a ball-peen hammer to drive it forward...
    bent the rear flange a little bit which pissed me off MORE than a little bit...
    i straightened it out but i dont want that crap happening again...
    thanks
  7. kevineleven
    kevineleven Member
    Columbus, Ohio
    Astro-glide
  8. Polock
    water, if you use lube it never gets tight,wears out the rubbers and the bolt has to hold it in place
  9. MiCarl
    I've never had to lube at all.
    Every time I've not had it just slip on with a little wiggling was because I had some sort of cable caught in the tank.
  10. Ltdave
    Ltdave Member
    yeah i thought that too but i can see the cables are up and out of the way...
    dang thing just wont slide on...
  11. brtsvg
    brtsvg Member
    Davenport, IA
    Use Sil-Glyde. Best stuff ever invented for these bikes, I use it all over the rubber parts and seals, makes putting things together much easier, especially the rubber-to-metal mating parts. You only need a very little to do the job.
  12. Gamuru
    Gamuru Guest
    Granite Falls, WA
    My tank pops right on, but my wife's... I have to straddle the bike, lift the tank up a bit, then wiggle it left and right while pushing forward to get it to seat. Hers is a tight fit for sure. I usually grip the tank on both sides down by the mounting flange then lean forward as a shove it onto the front grommets. It's all in the ass. ;)
