XJ Starting Problems
Discussion in 'XJ Technical Chat' started by mikez, May 6, 2008.
  1. mikez
    mikez New Member
    Good Morning All---New to site---Interesting stuff here. I restored an 85 Maxim XJ last year. Bike runs and handles great. One small plaguing problem. Bike will fire up first time every time---but you need to need to keep the RPM up until it warms up. If not, and it dies, I have a hard problem starting it back up. The enrichners don't appear to do anything in this state. After numerous tries, and almost as battery goes dead, it may fire up, when it does, I don't smell gas or a rich condition. As long as the engine RPM is high enough to prevent it from dieing during warm up, it will be OK.
    The carbs were clean out and synched. When the bike reaches operating temperature, she runs great, and idles great. I even tried using the "choke", and when the engine is warm and idleing-- using it will kill the engine. Reving it and using it on a warm engine does make RPM drop signiciantly, so I'm thinking the circuit is working.
    Any thoughts from anyone out there ??
  2. dorri732
    dorri732 New Member
    Toccoa, GA
    I've got a '82 650 Maxim that does the same thing. When it's warm out (70+), it starts fine, but any colder than that and it starts and then dies if I don't rev the snot out of it (not the best thing for a cold engine).
    I'm going to pull the carbs back off and check float levels, etc and see if it improves. Good luck.
  3. philbrewer
    philbrewer Member
    Livonia, MI
    Dorri
    Sounds like you need to clean your enrichment circuits. After I cleaned mine, approx 3-4 hours, the bike starts right up in the morning, no problems whatsoever.
  4. blair
    blair New Member
    Hr.Grace , Newfoundland
    Phil....please provide a brief explanation of cleaning enrichment circuits.
    Blair
  5. TMHack
    TMHack Member
    Green Bay, WI
