Fuse Panel
Discussion in 'XJ Technical Chat' started by wizard, May 5, 2008.
  1. wizard
    Out with the old and in with the new-
    I am now a fully paid up member of the sand pit club (ref: Rick)
    So why don't I feel that rosy glow?
    1/ the panel i ripped out was in very good condition
    2/ the build quality of the new panel is c--p
    3/ the spade connectors are all exposed
    4/ it looks amateurish
  2. MiCarl
    Really? Looks pretty good to me.
    If you're concerned about the connectors being exposed replace them with insulated ones.
  3. Gamuru
    Gamuru Guest
    Granite Falls, WA
    You could also unwrap some of that tape and open the two legs up a bit. That will help with how tight the wires are pulling on each other. The other trick I found is to bend the spade terminals protuding from the fuse block at about a 30° angle. This gives you a little better approach and relieves some of the stress.
  4. jafrance
    jafrance Member
    Plattsmouth, NE
    I wish someone would make a walkthrough for this......
  5. jeepsteve92xj
    jeepsteve92xj Member
    Milwaukee, WI USA
    Did you see Dons signature?
    1981 XJ650 Maxim (Mine)
    1982 XJ650 Maxim (My wife's)
    Author of several How-To's and the blog, The Path Less Traveled.
    yep, that how to's link is the place to go:
    http://xjbikes.com/Forums/viewtopic/t=8588/
  6. jafrance
    jafrance Member
    Plattsmouth, NE
    Thank you SO much for pointing that out to me. There are like 4 things on that list I need to read!
  7. pvtschultz
    pvtschultz Member
    Milwaukee, WI Area
    I removed the red plastic things from the connectors prior to installing them and then covered up all the bare metal with liquid electrical tape. Seems to be holding up well.
  8. martinfan30
    martinfan30 Member
    Carson City, Nevada
    Having trouble getting that fuse block. I did find one with six fuse slots.
    The only thing is, it has only one power supply post.
  9. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    wizard,
    I think it looks great!
    Not sure what cond "c--p" is...but i bet thats not good.
    you could cover those terminals with electrical tape if your feeling mildly unmotivated ;)
    and BTW who will even see the darn thing? besides you...
    Good Job
  10. pvtschultz
    pvtschultz Member
    Milwaukee, WI Area
    Here's the one that I used. Seems pretty nice.
  11. BlackRig
    BlackRig Member
    Olmsted Falls (Cleveland), Ohio
    I dont think it looks too bad. I probably would've opted for a enclosed fuse panel. Is that the one from chacal?
    Another tip to help clean it up: ditch the spade connectors. I've never had any luck with those cheap things. I would just solder the ends and use some shrink tubing. If the fuses are exposed it shouldn't be a big deal. You want them readily avalible if you blow one on a ride. And, unless you carry a knife AND xtra fuses, covering them in tape seems combersome.
    Other than that, I think the work looks professional! I think the materials used are more the problem than the workmanship.
  12. MGM8675309
    MGM8675309 Member
    Fort Worth, Texas
    I'd have to agree with this, no need for spade connectors anyway it's gonna be another 20-odd years before you need to unplug them again. :D
  13. RickCoMatic
    Get a small bottle of Liquid Electrical Tape and coat the connectors.
    The job is a good as it is done.
    I tookk the New Fuse Panel and Soldered NEW wire to the Terminal Ends.
    Heat Shrink over the Soldering-On
    Shaped the "New Pigtails" and taped them with Black Tape.
    Spliced the Fuse Panel's Pigtails to the wires coming from the Harness.
    Heat shrink over the soldered splices.
    Then, tape.
    The end result was that there was no Crimp-on connectors used.
  14. wizard
    This is my solution " the wizard patent console"
    now i'm happy.
  15. Robert
    Wiz, that looks downright spiffy! Nicely done indeed!
  16. RickCoMatic
    Nice work, 'Mate!
    Are you going to humor us with how you came-up with the Brainstorm?
    I'll bet there's a woman's touch to it in some way or another!
    It looks fine like that , I must say!
  17. wizard
    Your right, Rick,
    but I couldn't possibly tell her how she was involved.
  18. pvtschultz
    pvtschultz Member
    Milwaukee, WI Area
    More info!
    If you don't mind sharing...
  19. ryan_975
    ryan_975 Member
    Conway, AR
    That is nicely done. I think I have a tupperware lid around that'll work. Maybe I can sneak it by the wife... probably not.
  20. RickCoMatic
    "Honey, did you see the Tupperware container top for this one? I've looked all around and in the washing machine. I can't for the life of me find it!"
    "No, dear. But those things have legs and like to walk away. I'm sure it will turn-up sometime soon."
    (LOL)
