top of fork tubes
Discussion in 'XJ Technical Chat' started by boots, May 11, 2008.
  1. boots
    boots New Member
    selmer tn us
    The tops of my fork tubes are rusty and wollerd (striped) out,any suggestions on what to do?Thankyou again and I reallt love this site. :)
  2. southpaw
    southpaw Member
    new york
    Exactly what is stripped out. and what bike is it ???
  3. boots
    boots New Member
    selmer tn us
    the very top of both fork tubes has no type of rubber caps,it only has metal plate that looks like at one time there was a allen fitting,but now is striped out.The bike is a 85 xj700 maxin thankyou
  4. boots
    boots New Member
    selmer tn us
    how do the tops of the forks come apart?
  5. Alive
    Alive Active Member
    Queensland, Australia
    Hey Boots... Sounds like yours are the threaded caps with 19mm allen key holes to remove as opposed to a circlip holding them in.
    If the allen holes are stripped you are going to have a bit of a mission on your hands to remove them and they will then need to be replaced.
    good luck
  6. RickCoMatic
    Boots:
    If you are going to get into those forks ... Get a Manual!
    You just can't start taking the forks apart without knowing the lay of the land.
    Not only that, but if you make the wrong move you could get the bike in your lap.
    The forks are not complicated ... but, you should familiarize yourself with where you are going before starting the process!
    We'll answer the questions you have about doing the job once you have a handle on where it is you are heading.
  7. chacal
    Here you go! Boots, if your model is a 700 non-X version (air-cooled engine), then those alalen-key cap bolts do not use an o-ring, but there is a gasket beneath each one:
    HCP8287 OEM inner fork tube top plastic CAP, fits either the left or right side tube of the following models: all XJ700 non-X models. Each:
    $ 6.00
    HCP8292 OEM inner fork tube CAP BOLT, fits either side. Used on all XJ700 non-X and XJ900RK Seca models. Each:
    $ 25.00
    HCP8286 OEM inner fork tube CAP BOLT LOWER GASKET, fits either side. Used on all XJ700 non-X and XJ900RK Seca models. Each:
    $ 3.00
    HCP8286SET2 OEM inner fork tube CAP BOLT LOWER GASKETS, fits either side. Set of two:
    $ 5.50
    And what Rick says is very true, you need a manual!:
    HCP1143 Factory Service Manual covers all XJ700 non-X models 1985-86.
    $ 59.00
  8. FinnogAngela
    FinnogAngela Member
    Copenhagen, Denmark
    I think the Allen top is 17mm.
    If you use the search function (and Google) you´ll get lots of information about changing fork oil, fork removal, disassembly and changing fork seals (and evt. bushings) - I think there´s also a thread in the FAQ section.
    Front wheel has to be elevated securely and to get the top bolt out you have to loosen the upper pinch bolts (but not the lower ones).
    If an Allen top won´t get a grip, you may have to have it welded in (in which case it probably is best to remove the forks first :).
    You can always put them back in the tripple tree to get the lower pinch bolts to hold the inner tube while you turn your newly welded Allentopbolt with a big wrench.
    For parts diagrams and manuals I suggest you get the XJCD: http://members.tripod.com/dave_jack/id47.htm
    Good luck with the project
  9. FinnogAngela
    FinnogAngela Member
    Copenhagen, Denmark
    Len, on my 700 (non-X) the top bolt had an o-ring, which is also shown in the Service manual - the parts diagram however refer to it as a gasket..
    S´pose you could use either one..
  10. chacal
    Hmmm....Yamaha calls it a gasket. Might be an o-ring. Have to check inventory and curse the parts book proofreaders some more if it turns out to be an actual o-ring.........thanks Finn!
  11. boots
    boots New Member
    selmer tn us
    Hey this is boots saying thankyou so much for the info,yall are the bomb.
  12. FinnogAngela
    FinnogAngela Member
    Copenhagen, Denmark
    Boots, you´re welcome
    Let us know how it works out (pics are allways nice :)
