ATF fluid or fork oil?
Discussion in 'XJ Technical Chat' started by kar98k, May 20, 2008.
  1. kar98k
    kar98k New Member
    Middleboro, Ma
    I am doing the fork seals in my 82 xj 750 seca i have always used automatic transmission fluid (ATF) in the forks on all of my other bikes but this bike calls for 20wt fork oil. can i still use ATF fluid or will it damage the forks?
  2. Robert
    Do not use the ATF, use 10w/30, 309cc each side. Drain and refill at first opportunity.
  3. kar98k
    kar98k New Member
    Middleboro, Ma
    i havent put the atf in yet cause my forks are in a million peaces atm but 10w-30 motor oil? never heard that b4. i have 15w-40 at the shop where i work can i use that ?
  4. RickCoMatic
    My XXXL sized body needs some real dampening up front.
    I use Permatex Hydraulic Jack Oil.
    No problems and very little (none) bottoming-out up front.
  5. kar98k
    kar98k New Member
    Middleboro, Ma
    well ty for the help i still am crying cause the last moron to own the bike striped the Allen bolt on the bottom of the left fork and i cant figure out how im gonna get it out and of course its the left that needs to be done. i think he did the right striped the left and gave up cause the boot on the left looks older than the right
  6. Altus
    Altus Active Member
    London, Ontario
    I'm a big boy too, and when I put the Progressive springs up front, I also switched to 15wt fork oil -- been wonderful ever since
  7. tylernt
    tylernt Member
    Idaho
    I am following this thread with interest. I'm using ATF and I have lots of front end dive when using the front brake. I was considering 10W40 to stiffen it up some...
  8. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    Anyone tried the "cartridge Emulators"?
    ( the little gold thingies in the wish book)
    They say they improve the ride.
    But how?
  9. RickCoMatic
    They make the front end lighter by eliminating a couple of hundred dollars from your wallet.
  10. stereomind
    stereomind Active Member
    Tulsa, OK
    Are you sure it's stripped out, and not just the nut spinning inside the fork tube?
  11. one2dmax
    one2dmax Member
    We have been using a special blend of ATF that is made by BG Products. It is the "green" colored synthetic fluid. It does not break down the rubber and aluminum like normal fluids do and as such they last much longer.
    The head experimental tech at BG is one of our members in the Vmax club and the head quarters are located here which is how I came to meet him and get him joined up. He has a number of other Yamaha's too.
    Sean Morley
  12. Danilo
    Danilo Member
    Vancouver canada
    Cartridge Valve Emulators ..WORK.. Period (only doubters are those who not yet experienced them :) AND they Cost a whopping $49 if bougt from MikesXS.com (Lookunder suspension bits top of page)
    ATF is 7 w oil.. No surprise as to why yer not getting much fork dampening action .
  13. tylernt
    tylernt Member
    Idaho
    Huh, I thought it was 0W20. But I've been wrong before! :oops:
  14. kar98k
    kar98k New Member
    Middleboro, Ma
    well im going to try rotella T 15w40 cause i have gallons of it at the shop and i happen to enjoy a really stiff front end. on all or my chopper projects i have always used springer front ends and have grown accustom the the feel. plus on a bike where i sit as forward as this one i really want a stiffer front end.
    Thank you for all the help guys
