stupid bike won't idle (83 750 Maxim)
Discussion in 'XJ Technical Chat' started by fiater, May 27, 2008.
  1. fiater
    fiater New Member
    Annapolis, MD
    Can keep an idle with choke, but would rather not. Turned in the center knurled pretty far til it would hold idle, but when I rode it, it would rev on it's own to 4k. I haven't looked too hard, but I don't think this is just an idle screw.
    You think it might just be a matter of the throttle shaft seals (2 each carb)?
    It runs superb, and I don't want to start pulling these apart (not to mention all the cost of all the gaskets/seals and such) and risk ruining how it runs now.
    Anyone run into this prob before? I had to turn the center screw all the way back to it's original position so it would run well, but then of course no idle.
    Also, what are the adjusting screws on the levers between the carbs for? Is that so they all actuate at the same time/throttle position?
    I'm really more used to the sliding throttle bore with the attached needle found on dirt bikes and stuff. Not too familiar with these vacuum ones.
  2. mac11
    mac11 Member
    Outside Chicago
    you don't want to do it, but you have to.
  3. bstig60
    bstig60 Member
    Sharpes, Florida
    Could be a vacuum leak.
  4. martinfan30
    martinfan30 Member
    Carson City, Nevada
    Do you also have a sputtering issue at 3500-4000 RPM?
  5. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    FIRST;
    have the carbs been synced, prob not b/c those screws you speak of are the sync screws.
    This NEEDS to be done, so heres a link to the How-To
    http://www.xjbikes.com/Forums/viewtopic/t=2132.html
    When the syncs are incorrect funny things happen.
    If you do suspect a vacuum leak AFTER you sync...
    Get a propane torch
    and run the unlit torch over the suspect leak spots. If idle increases you have found a vacuum leak.
    EDITOr your mixtures are too lean...
  6. martinfan30
    martinfan30 Member
    Carson City, Nevada
    Wouldnt brake cleaner do the same thing?
  7. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    I have never heard of the propane torch trick. I like it.
  8. bstig60
    bstig60 Member
    Sharpes, Florida
    WD 40 does just as well to find Vacuum leaks and it doesn't explode in a confined area.
  9. mac11
    mac11 Member
    Outside Chicago
    propane is actually very stable.
  10. fiater
    fiater New Member
    Annapolis, MD
    But isn't it ill advised to try and sync with a known prob (likely vac leak). Maybe I should try the propane - great tip BTW. As far as I know, it's never been synced (33k) and I'm sure it needs it, just wondering if it's worth it knowing how much I ride (but it is so fun I may put serious miles on it). Also, I have no sputtering anywhere in the rev band, which is why I'm hesitant to pull them apart.
    Anyone know if the knurled screw facing rearward from the center of the carbs is strictly for idle? Is the idle controlled by vacuum too, and not just a lever stop?
  11. mac11
    mac11 Member
    Outside Chicago
    obviously you want to get any vacuum leaks or mechanical issues sorted before you try to tune it.
    if there is no vacuum leak you likely need to pull the rack and clean the carbs.
