Throttle not releasing properly during shift
Discussion in 'XJ Technical Chat' started by bstig60, Jun 6, 2008.
  1. bstig60
    bstig60 Member
    Sharpes, Florida
    I have a problem that I have not been able to find an answer for using search........
    On occassion when I release the throttle to shift gears, the engine races. The throttle is back to idle as far as I can tell. I have checked it while the bike is not running and the throttle snaps back as it should. I have checked the cable and lubed it just to be sure, but this seems to be happening more often. Has anyone run into this? SECA 750
  2. switch263
    switch263 Member
    Austin, TX
    My 81 Seca 750 was doing exactly this, and it seemed to be related to my sync and mixture issues. Does your bike idle properly on its own? Or does the engine "race" instead of idling? Mine really didn't want to "idle" properly at all, and the self-revving was a result of that; When i'd grab the clutch, it would release pressure on the engine and let it spin as fast as it wanted.
  3. bstig60
    bstig60 Member
    Sharpes, Florida
    It idles properly...... When I grab the clutch the rpm's stay up and gradually drop, but not nearly as fast as they should. I just got back off a 500 + mile trip and I started noticing it occassionally toward the end of the ride.
  4. bstig60
    bstig60 Member
    Sharpes, Florida
    Doh! Doh! I feel kinda stupid! Doh! The problem with the slow releasing throttle had to do with "end play" on the throttle grip. There wasn't any there and it was binding on the holder assembly. See how simple that was?? Doh!
  5. RickCoMatic
    That was fast!
    Glad that one worked-out without anything involving removing the carbs and checking float heights, bench syncing and setting Pilot screws.
    Easy as pie!
  6. bstig60
    bstig60 Member
    Sharpes, Florida
    Just took a 50 mile ride to check it out and it worked grrrrreat!
  7. RickCoMatic
    You didn't need to go 50 miles.
    Just a few miles would have checked it.
    You rode 50 Miles for the FUN of it ... huh?
    Don't fib!
    You just needed and excuse to go riding the bike!
  8. bstig60
    bstig60 Member
    Sharpes, Florida
    So I did!
  9. flash1259
    flash1259 Member
    W.R. Wisconsin
    I do love a simple fix.
    rode the 49.9 miles for the fun of it. LOL
    been raining here for about 4 days now and no end in sight yet. next sunday 84°f and partly sunny. maybe get an hour or so on the bike. SIGH!
  10. bstig60
    bstig60 Member
    Sharpes, Florida
    Rainy season is over in Northern California. We may get a shower in July or August but no major rain until November.
