$1 Card Boots!
Discussion in 'XJ Technical Chat' started by nickr, Jun 9, 2008.
  1. nickr
    nickr Member
    York,PA
    I own an 82 XJ1100. I need to replace the carb boots but not sure where to buy them. I know I am running Mikuni carbs but not sure of the model. cant find it printed on the cast.
    I looked on MikesXS and found some boots but not sure which ones I need.
    Does anybody know where to get these for the best price.
    Thanks so much.
  2. schmuckaholic
    California
    You talking airbox-to-carb boots or carb-to-manifold boots?
    I just poked through Chacal's price list, and he doesn't seem to have the airbox-to-carb boots for the 1100. He does have manifold boots, on the other hand (plus the gaskets, seals, clamping rings, vacuum caps. mounting bolts...)
  3. chacal
    RUBBER INTAKE MANIFOLDS & RELATED:
    ww7) OEM and reproduction INTAKE MANIFOLDS, both original and reproduction individual manifolds and complete sets are offered to allow you to replace cracked, dry-rotted, vacuum-leaking (making carb tuning impossible......) originals. These are the vulcanized rubber-over-aluminum tubes that run from the front of the carbs to the cylinder heads!
    NOTE: the reproduction manifolds are excellent quality, basically indistinguishable from the originals. However, the gaskets that come with them are a very thin paper style, much less substantial than the originals, although they probably will work okay. You might want to consider buying some of the original manifold-to-head gaskets when ordering a reproduction kit.......
    HCP1230 Reproduction Yamaha rubber INTAKE MANIFOLDS, complete set of 4 intake manifolds (2 left and 2 right). OEM quality at a better price! Includes a set of 4 manifold-to-head gaskets. Fits all XJ1100 models. Set of 4:
    $ 144.00
    ww8) Yamaha intake manifold-to-head GASKET and O-RING. Seals the intake manifold to the cylinder head mating surface. A "must-replace" item whenever the intake manifolds are removed for any reason.
    HCP6324 OEM intake manifold-to-head GASKET, used on all XJ1100 models only. Each:
    $ 8.50
    HCP6324SET4 OEM intake manifold-to-head GASKETS, set of 4:
    $ 32.00
    im4) OEM intake manifold metal CLAMPING RING, includes the cinching screw. These are used on the carb end of the manifold only.
    HCP2894 OEM intake manifold metal CLAMPING RING, used on all XJ1100 models, each:
    $ 7.00
    HCP2894SET4 OEM intake manifold metal CLAMPING RINGS, set of 4:
    $ 24.00
    P.S. your carbs are Mikuni BS-34 series, here are the specs:
    XJ1100
    Mikuni BS34
    Model #10M00
    -Main Fuel Jets: #112.5
    -Pilot Fuel Jets: #47.5
    -Main Air Jets: #140 (in throat, non-removable) ????? s/b 40??
    -Pilot Air Jets: #170 (in throat, removable)
    -Air. Comp. Jets: none
    -Starter Jet: #25 (in bowl, 2-stage)
    -Needle: 5GLZ-34
    -Emulsion Tube/Needle Jet: X-2
    -Butterfly: stamped #135
    -Float Valve Seat: ~2.0mm
    -Idle Speed: 1100 rpms
    -Throttle Valve:
    -Float Level: 3mm +/- 1mm (.12 +/- .04 inches)
    17.5mm +/- 1.0mm (0.69 +/- .04 inches)
    1100 are 55.05mm intake OD
    1/2 and 3/4 throat spacing = ~>3"
    2/3 throat spacing = ~3-1/4"
  4. schmuckaholic
    California
    I was trying to avoid pasting all that if he didn't need the manifold boots...
  5. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    aww. And I was hoping to get a set of $1 carb boots. lol
  6. nickr
    nickr Member
    York,PA
    Yeah I am loking for the manifold boots. I thought maybe they were offered somewhere else. $144 is a little steep for this old XJ.
    Sorry Gwyndwr. didn't want to upset anyone. I would like to find a good deal too.
    Thanks for the replies.!!
  7. nickr
    nickr Member
    York,PA
    Woops chacal
    Thanks for the great info.:)
  8. miksatx
    miksatx Member
    san antonio, tx
    just replace all the boots and be worry free for the next 10yrs
  9. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    You could just seal them on the inside.
  10. mlew
  11. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    Those should work.
  12. chadly89
    chadly89 Member
    brownsvalley california
    i just ordered a set for my 550 off of www.carbkitscapital.com and it was 86$ and anything over 50 has free shipping fight now
