#4 is cold, oh wait, not anymore.
Discussion in 'XJ Technical Chat' started by weoxstan, Jun 17, 2008.
  1. weoxstan
    weoxstan Member
    Central Michigan
    I started it up today and ran it with the choke for couple of minutes to warm it up. I kept feeling #4 head/jug and it was not warm so I felt the others and they were. So I did a quick tap on each header to see which cylinders where working. Looks like just #4 was not firing. Note: the exhaust was whitish. I turned off the choke and it stayed running. I reved it up a few times and held it at mid to low RPM range. (Tach not functional) I let of the gas and turned it off, and refelt the headers. All 4 are hot, #4 was not as hot as the others though. I pulled the plugs and 1, 2, 3 are all black, IE rich. Number 4 was tanish in color.
    Other info: carbs just cleaned with new pilot springs, washers and o-rings. All set at 3.5 turns out. I am building a DIY manometer and YICS tool but don't have them done yet. (Looking for high temp silcon tubing and 3 or 4 way 3/16" vacuum fitting) So I know I need to tune it yet.
  2. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    That is a common symptom of a bike with just cleaned carbs and no tuneup or colortune performed yet. If #4 was tan while the others were black I would suspect it to be lean. All should have been black since it had run with the choke on. Most likely the lean condition is due to a still clogged starter jet. This would be the one in the bottom of the float bowl. If is only needed for start up so I would worry too much about it until you get the bike tuned and see if that one runs well off the pilot & main jets.
  3. weoxstan
    weoxstan Member
    Central Michigan
    I was thinking it was the carbs, it's always the carbs. I think I have read that few times...
    I will probilby pull the bowl off #4 and reclean that jet. Might as well make sure everything is good to go. I may give it a seafoam treatment first to see if that clears it up. As for it running rich with the choke on, which is understandable, how long will I have to run it with the choke off inorder to clean the plugs up? That is assuming the carbs are sync'ed and tuned. Are we looking at minutes, seconds?
  4. MonkeyWrench
    MonkeyWrench Member
    Mid Michigan
    I had the same problem after a good cleaning of my carbs. Turned out that the enrichment circut on #4 was plugged. The hole in the front of the bowl that the enrichment tube lives in was not filling from the bowls main chamber. #4 wouldn't come to life until I gave it some revs, and would obviously run lean compared to cyl 1-3 when the choke was on.
    Be careful when shooting carb cleaner through this circuit. It will go exactly where the opposite end is aimed and travel a good distance with incredible preciscion. For me, it was first my eye and then the windshield on my snowmobile.
  5. switch263
    switch263 Member
    Austin, TX
    Haha, i think this happens to everyone at least once. I seriously can not over-state how painful carb cleaner is when it meets your eye. Wear goggles, please!
