nearly there
Discussion in 'XJ Modifications' started by rubberlips, Jun 14, 2008.
  1. rubberlips
    rubberlips New Member
    ireland
    hi all,well im nearly finished triking the 1100 maxim.got some painting left to do and connect up the brakes,it should be ready for road again soon.
  2. Anthony14
    Anthony14 Member
    Mississauga, Ontario
    Dude that's pretty cool! Some more pics would be nice!
  3. Stamplicker
    Stamplicker Member
    London Ontario
    Yes More Pics!!!! Damn!
  4. Ease
    Ease Member
    NL, Canada
    Whaaaaaaaaaaaaaaaaat!?
    Sick frame!
    Dirtbike front wheel??
  5. rubberlips
    ireland
    hi and thanks ,ill put up some more pics.
  6. rubberlips
    ireland
    got a bit of work to do to the sissy bar yet.
  7. rubberlips
    ireland
    another
  8. rubberlips
    ireland
    i still have to finish off the front fender.the frontend is off a ktm,got to change the tire for a road one.
  9. KAOS
    KAOS Member
    Newport, Maine
    Damn Dude!!! Rock on with that "Trike"!!! :twisted:
  10. MidniteMax
    MidniteMax Member
    Liberty SC
    Cool ride!
    Kind of hard to tell from the photos how the driveshaft connects to the differential.
    Got any close up photos of that area?
  11. rubberlips
    ireland
    hi,i will take a picture of that later.im painting the shaft so its not on in the picture.i cut the shaft in half off the car axle,& the bike shaft,put a bearing the right size over the section from the bike and slid it into the car shaft.drilled a metal plate and welded it on the end.turnes perfect no shake at all.get you a pic later.
  12. MidniteMax
    MidniteMax Member
    Liberty SC
    That machine has some really nice lines. Looks like you set it up right.
    Rock on!
  13. rubberlips
    ireland
    hi the front end is off a ktm,need to change the tire for a road one,but my wife would rather buy food for my five kid's than let me buy the tire so ill have to wait awhile i guess
  14. rubberlips
    ireland
    hi midnitemax,hope this picture is allright.
      File size:
      117.6 KB
      3,035
  15. Stinky
    Stinky Member
    Flagstaff, Arizona
    Looks fun. How does it ride?
  16. Great_Buffalo
    Great_Buffalo Member
    43.719908/-98.030276
    Lookes Mad Max with that front tire. Where did the diff come from?
    Thats a rockin ride. Kudos
    The Buff
  17. rubberlips
    ireland
    hi,the differential and axle are off a robin reliant car.i cut down the axle and half shaft to make it narrower ,and line up the drive shaft.
  18. Ease
    Ease Member
    NL, Canada
    Not a bad idea for the inverted forks.
    Did it bolt right on or was there a bit of fab work?
  19. seca750
    seca750 Member
    New York
    Love the Bike, sorry Trike!
    I was wondering how the XJ would look with inverted forks! Very Nice! You got the front off a KTM, what year any pic on the assembly?
  20. rubberlips
    ireland
    hi,no it dident bolt right on, the center neck bar on the ktm was bigger.i had to remove that & take the center neck off the origional triple trees from the xj not easy it was welded ,but it went in the ktm triple trees good.then i had to make brackets to take the gauges ,ignition switch,and had to make a front fender because the ktm forks carry the fender right under the triple trees.but there good strong forks & about 3 1/2" longer than the xj.i cut the neck too and increased the angle a little bit.thanks
  21. RevsXJ650
    RevsXJ650 New Member
    Great job, keep up the great work!!
    Rev
  22. rubberlips
    ireland
    hi,i have no idea what year the ktm was,the guy i got them off had no idea.i dident take many pictures of the build,i really should have though.ill put up a few.this is the neck cut,i pulled it back in some from that position though.
      File size:
      97.6 KB
      1,969
  23. rubberlips
    ireland
    the swing arm,i just have struts on in the picture,so i wouldent scratch the shocks
      File size:
      112.5 KB
      1,966
  24. rubberlips
    ireland
    it was a drum brake axle.i converted it to disc they are volkswagen golf calipers
      File size:
      109.9 KB
      1,963
  25. rubberlips
    ireland
    another of the neck.most of the pictures i took were of wiring,so ide know how to put it back togeather again when i stripped it to paint the frame.thanks
      File size:
      118.4 KB
      1,959
  26. RickCoMatic
    Nice touches all over!
    Love them rear wheels big-time!
    I don't know how many trikes there are using a XJ Platform, but yours is one of the nicest looking trikes I've see with a YAMAHA Platform.
  27. rubberlips
    ireland
    thanks for all the good comments.
  28. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Not a big fan of trikes, but that looks awesome!!
  29. rubberlips
    ireland
    hi ,i did it to carry the the young fella around with me ,wont take him on the bike anymore.i hit a wall this time last year on a dragstar,that hurt i can tell you,the nerves are not the same now.
  30. yamason
    yamason Member
    Port Elgin Ontario
    Looks like it will be a show stopper Very nice.
  31. MidniteMax
    MidniteMax Member
    Liberty SC
    Hey Rubberlips.
    I was looking through some of last year's posts and came across those of the cool looking trike you were building.
    Did you ever finish it?
    Got any new pix?
  32. rubberlips
    ireland
    hi,i changed the front end to 65mm inverted 8" over.drive's perfect.i cant upload any picture's,dont know what the problem is
  33. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Rubberlips,
    Awsome looking trike! I like how you made the frame work for the rear wheels. Nice clean looking mod with a touch of custom work looks like you enjoy fabricating much like myself. I like when people think "out of the box" and do their own thing and your thing looks great! Just what I need for these Minnesota winters!!
  34. rubberlips
    ireland
    thank's,ill try and upload some pictures again soon,right now i dont have the patient's for it.thank's again
