WTB: Fork Emblem xj650 maxim
Discussion in 'For Sale, Trade/Swap, Wanted' started by keithwood87, Jun 19, 2008.
  1. keithwood87
    keithwood87 New Member
    PM me if you have one thanks.
  2. xyxj650
    xyxj650 Member
    Fergus Falls MN
  3. chacal
    Here they are! In stock and ready to ship:
    Fork Emblems:
    ed3) OEM and reproduction front FORK EMBLEMS fit on the lower steering crown "underbracket" and usually spell out the name "YAMAHA" in big letters against a chrome or black background. This emblem really details up the front end, as well as hiding the brake hose junction block(s) and the steering bracket.
    HCP2490 OEM front FORK EMBLEM, for all XJ550 Maxim and 1981 XJ550 Seca models. Although not correct for '82-3 XJ550 Seca models, this emblem will fit those models, too.
    $ 44.95
    HCP2448 OEM front FORK EMBLEM, for all XJ650 Maxim and 1983 XJ750 Maxim models. Although not correct for XJ650 Midnight Maxim aor XJ750 Midnight Maxim models (different coloration), this emblem will fit those bikes, too. Chrome plated plastic with black YAMAHA wording.
    $ 44.95
    HCP2468 OEM front FORK EMBLEM, for all XJ750 Seca and 1982 XJ750 Maxim models. Chrome plated plastic with black YAMAHA wording.
    $ 39.95
    HCP2509 OEM front fork emblem MOUNTING BOLT, use 2 per emblem, for all XJ550 models, each:
    $ 4.50
    HCP2509 OEM front fork emblem mounting bolt CAP PLUG, use 1 per HCP2509 bolt, for all XJ550 models, each:
    $ 2.95
    HCP2464 OEM front fork emblem MOUNTING SCREW, use 2 per emblem, for all XJ650 Maxim and 1983 XJ750 Maxim models, each:
    $ 1.25
    HCP2474 OEM front fork emblem MOUNTING SCREW, use 2 per emblem, for all XJ650 Midnight Maxim, XJ750 Seca models, 1982 XJ750 Maxim models, and XJ750 Midnight Maxim models, each:
    $ 1.00
    HCP2511 OEM front fork emblem MOUNTING SCREW, use 2 per emblem, for all XJ650 Maxim and 1983 XJ750 Maxim models, each:
    $ 0.95
    HCP2495 OEM front fork emblem MOUNTING SCREW, use 2 per emblem, for all XJ1100 models, each:
    $ 1.25
    HCP2508 OEM front fork emblem mounting bolt WASHER, use 2 per emblem, for all XJ550 models, each:
    $ 0.50
    HCP2512 OEM front fork emblem mounting bolt WASHER, use 2 per emblem, for all XJ650 Seca models, each:
    $ 0.50
    HCP2462 OEM front fork emblem mounting bolt WASHER, use 2 per emblem, for all XJ700 models, each:
    $ 0.50
    HCP2462 OEM front fork emblem mounting bolt NUT, use 2 per emblem, for all XJ700 models, each:
    $ 0.50
  4. snakesz
    snakesz Member
    ohio
    i have one for a 550 and its in perfect shape
  5. keithwood87
    Will a 550 emblem fit a 650?
  6. Altus
    Altus Active Member
    London, Ontario
    No - different connection methods
  7. keithwood87
    Thanks altus. Still looking for that emblem, used. Anyone?
  8. hogfiddles
    What kind of condition are you looking for? I have one with a lot of the plating worn off.........
