1972 TX750 any thoughts!?!
Discussion in 'Other Motorcycles' started by KAOS, Jun 4, 2008.
  1. KAOS
    KAOS Member
    Newport, Maine
    I'm looking at an 1972 TX750. So I can "Bobber"! :twisted: I searched the "net" 4 info about the bike. But really didn't much...
    Anyone know anything about this bike? Any info would be sweet? (Should I stay away? buy it? etc...) N yes the price is "right" :wink:
    Thanx
    KAOS
  2. danno
    danno Member
    Union Springs,New York
    Avoid it like the clap! The engine had a poor internal oiling system,so top end seizures were common. If you want to bob a twin cylinder Yamaha,an XS 650 would be a much better (although pricier) choice. Parts are much easier to source for the 650,as well.Perhaps someone else can confirm or dispute this,but I would be incline to pass on this one.
  3. KAOS
    KAOS Member
    Newport, Maine
    Believe it or not. i found a site or 2 that said "almost" the same sh!t as u.... I guess the bike is "Not WORTHY" 2 Bobber! N is hard 2 get parts 4!
    I can get XS's 4 some "decent" prices... So I guess I'll that route. With my "Bobber" build! :twisted:
    Thanx
  4. TIMEtoRIDE
    The bike was an embarassment to Yamaha.
    Even the factory techs couldn't make it run right, when it was new.
    So it's very rare, if you keep it original.
  5. KAOS
    KAOS Member
    Newport, Maine
    I can get it 4 "really" cheap. Low mileage n all. Should I buy it then re-sell 4 some profit!?!
    Thanx
    KAOS
  6. TIMEtoRIDE
    I bet you can't find somebody who is using this particular model as reliable transportation (like going to work, taking trips).
    If you retro-fitted electronic ignition, and swapped carbs from, say, the Kawasaki LTD 750 (another 2 CYL) and ran really good oil, you might end up with a rare bird that actually runs. You have to want to ride a Yamaha that nobody has ever seen.
    Or just pass on it.
  7. danno
    danno Member
    The best oil in the world is useless if doesn't circulate properly throughout the engine. There is a reason there isn't many of these bikes left...they had a poorly designed engine oiling system,and usually met an early demise.
  8. Ltdave
    Ltdave Member
    i wonder if any pics exist...
  9. KAOS
    KAOS Member
    Newport, Maine
    With all my search's n all. I only found pics of the TX550's. Of the same year...
  10. spinalator
    spinalator Member
    Regina, CANADA
    Get the suzuki with the rotary engine. They are rare and sound like a pimped out Mazda RX-7.
  11. KAOS
    KAOS Member
    Newport, Maine
    Any info on that bike!?! year? etc... I "LOVE" rare (Things).... Thats how I DO... :D 8) :twisted:
  12. spinalator
    spinalator Member
    Regina, CANADA
  13. spinalator
    spinalator Member
    Regina, CANADA
    I dont think it will make a babber, but mebbe a cafe racer
  14. wizard
    the early XS is a classic, go bob something else.
  15. cycleman
    cycleman Member
    Regina, Saskatchewan
    There is actually several sites with info on the 73/74 Yamaha TX750 if you do a little digging on the web. In many ways it was way ahead of its time but Yamaha's timing was bad as everybody started building 4 cylinder bikes not 2.
    There were several factory mods to these bikes that helped. The 74 model is generally the better one to get as they had most of the issues sorted out.
    The biggest single issue with these bikes was that they were a dry sump bike with chain driven counter balancers that churned up the oil so bad at high RPM's that it starved the crank of oil and they blew up. Serval factory mods included deeper oil sump, oil cooler and adjustable counter balancer.
    Yes they are scarce and parts are almost non existant. You are looking at a situation where you'd have to get a couple or more bikes to make one good one.
    I'm currently looking at picking up 2 of these bikes to try and make one as I'm looking for a restoration project and either something like this or a 75/76 Goldwing should keep me busy. I've done about all I can with my Maxim.
  16. Ease
    Ease Member
    NL, Canada
    ***EDIT: The pics are a TX650... OOPS!***
    Here are a couple pics of a TX750 custom... Mild cafe racer.
    (And second place ribbon winner)
    Bike is owned by Mortikan over on DoTheTon.com if you want to discuss the TX's downfalls / high points.
  17. KAOS
    KAOS Member
    Newport, Maine
    If I get a XS. I'll do a cafe build.
  18. desertdog
    desertdog New Member
    Sachse, TX
    This is a TX750, and they aren't worth the metal they are made out of...
  19. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    Apparently, amongst their many faults, the counterbalancer chain would stretch, which would allow the balancer to go out of phase with the crankshaft, with hilarious results.
    Bob an old KZ750 twin. They were ugly and slow to begin with, so it would be hard to make it worse than it already is.
