Thoughts on a dual disc upgrade
Discussion in 'XJ Modifications' started by ZaGhost, Jun 30, 2008.
  1. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    1,Are there any dual disc XJ wheels that would fit and Max 400?
    2, Would it be worth the work?
    It's a 19" wheel , tire is a 100/90
    I'm planning a SS braided line upgrade later, wondering if this path is worth looking into.
  2. PaintIt(Flat)Black
    PaintIt(Flat)Black Member
    Sterling, MA
    im not positive about the fitment... should fit, but my seca 750 has dual brakes and is a 19" with 100/90 tires.
  3. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    750 seca should work
  4. scarecrow
    scarecrow Member
    Dunnville, On
    that's what i'm doing with my 82 650 maxim switching the front forks with a 82 seca that i have for a parts bike
  5. TMHack
    TMHack Member
    Green Bay, WI
    My front forks/wheel are from a 650 seca turbo and the calipers/rotors are off a 02 R6. They work great! Needed to fab up some mounting brackets for the calipers but the rotors screwed right into the rim with no issues.
  6. acergremlin
    acergremlin Member
    NE UK
    *** misspost***
  7. ZaGhost
    ZaGhost Member
    Hmmm thanks guys, now I have food for thought :)
  8. PaintIt(Flat)Black
    Sterling, MA
    if 02 R6 rotors screwed right on would the wheel on an R6 also fit a seca/maxim... just curious... although im not sure about the rear wheel.
  9. caddymankc
    caddymankc New Member
    Are the rotors the same as stock or are they diffrent size and dish? New rotors could help out my front brakes.
  10. TMHack
    TMHack Member
    Green Bay, WI
    I don't think the fronts wheels are the same, different sizes but not 100% sure. I still have the stock rotors so I will check. The front end is not the stock front end from my 550 though, it's from a 650 seca turbo(don't know what year).
  11. bigfitz52
    Your Maxim 400 isn't heavy enough to really NEED dual discs; I had considered doing the same thing to my Seca 550 until I found out about EBC's line of aftermarket high-performance aftermarket FLOATING rotors. For about $200 you can replace the rotor and pads and modernize your front brake (and lighten the front wheel assembly at the same time.) http://www.ebcbrakes.com/mb-streetbikes.html Take a look at the "Pro-Lite series (about halfway down the page.) I'm gonna go this route on my 550.
  12. ZaGhost
    ZaGhost Member
    Oooh nice, definate a better alternative I think, after thought were preplac ing the front forks with the 750 forks (or fabbing a bracket to hold the 2nd caliper) I'll check into this idea....
    Checked through the link, did some reading, they are carried by 2 local shops... sweet. Now to figure out sizing and fit. Are most Yammy rotors of this era close to the same? Also, how do you think these compare quality/price wise to the performance rotors carried on MikesXS?
    May take a close look at my pads today and see what the wear is.
    Mya check their drum brake shoes as well... (though mine seem to work quite well atm) future reference. Braking seems to be the biggest weak spot on the bike.
  13. bigfitz52
    You can figure out which part number your bike takes on the EBC site, but it's kinda goofy. There's a link to click on http://www.ebcbrakes.com/Assets/08%20US ... ations.xls
    that will download their applications list in Excel format, then you search on your bike for the PN. Took me a while to find it.
  14. chacal
    Be careful on using EBC applications charts........on many of the models, they seem to have confused Eur model XJxxx models with their US counterparts. On some models (such as the XJ750's which used the same discs for both US and Euro models) it's not an issue, on the XJ550 and XJ650 models it may lead to a certain amount of "confusion".
    It certainly did for me when I was investigating their product line. It took 3 months of research and effort to get things right. Somehow, I doubt that other retailers take that amount of time (or have the time to dedicate to one segment of their entire product line) to figure it all out......
    However, as pointed out, they are worthwhile, high-quality products and are basically the ONLY replacement OEM-fit rotors available:
    Disc Brake Rotors:
    br1) OEM and aftermarket front and rear disc brake DISC BRAKE ROTORS, brand new units exactly replace damaged or worn out originals.
    Original OEM units exactly replace your originals.
    High-performance aftermarket EBC Rotors not only fit correctly, but also feature a cross-drilled disc with over-lapping holes to prevent disc "ridging" as the pads and disc wears. This spiral "birds-wing" drilling pattern promotes maximum rotor cooling efficiency (not to mention cool looks!) as well as being significantly lighter than the stock rotors.....and on models that use an offset center hub, these floating-design (riveted hubs) provide significant weight savings over the stock rotors, helping to improve both the handling and braking characteristics of your bike. Their precison-ground HSPR low-carbon steel is basically fracture-proof.
    Rotors should ALWAYS be replaced in pairs, or adverse and dangerous braking response could result.
    And ALWAYS replace disc brake pads when installing new rotors!
    The minimum thickness for original rotors is as follows (they specifications do NOT apply to aftermarket rotors). The maximum allowable "runout" or warpage is .15mm high-to-low for all models, all rotors:
    4.5mm for all XJ550 models, all XJ650RJ Seca and XJ650 Turbo models, all XJ700 models, and all XJ750 models.
    6.5mm for all XJ650 Maxim and Midnight Maxim models, and all XJ1100 front and rear rotors.
    7.0mm for all XJ950RK front rotors.
    8.0mm for all XJ900RK rear rotors.
    Original Rotors:
    HCP743 OEM front Disc Brake ROTOR, right or left side, fits all XJ700 models.
    $ 249.00
    HCP745LH OEM front Disc Brake ROTOR, left side, fits all XJ750 Maxim and 750 Midnight Maxim models.
    $ 309.00
    HCP745RH OEM front Disc Brake ROTOR, right side, fits all XJ750 Maxim and 750 Midnight Maxim models.
    $ 339.00
    HCP744LH OEM front Disc Brake ROTOR, left side, fits all XJ750 Seca models.
    $ 299.00
    HCP744RH OEM front Disc Brake ROTOR, right side, fits all XJ750 Seca models.
    $ 219.00
    HCP746RH OEM front Disc Brake ROTOR, right side, fits all XJ900RK models.
    $ 289.00
    Aftermarket High-Performance Rotors:
    NOTE: all floating-hub design rotors come with a natural finish to the central hub section, which you may wish to paint black (or gold in the case of Midnight Maxim models) in order to duplicate the original color scheme of stock rotors.
    HCP4130 Aftermarket front Disc Brake ROTOR, left side, spiral drilled cooling holes with a fully-floating, riveted hub design, fits all XJ550 Maxim and XJ750 Seca models.
    $ 195.00
    HCP4131 Aftermarket front Disc Brake ROTOR, right side, spiral drilled cooling holes with a fully-floating, riveted hub design, fits all XJ550 Seca and XJ750 Seca models.
    $ 195.00
    HCP4133 Aftermarket front Disc Brake ROTOR, left side, spiral drilled cooling holes with a fully-floating, riveted hub design, fits all XJ650 Maxim and Midnight Maxim models, and XJ1100 models.
    $ 195.00
    HCP4134 Aftermarket front Disc Brake ROTOR, right side, spiral drilled cooling holes with a fully-floating, riveted hub design, fits all XJ1100 models.
    $ 195.00
    HCP4132 Aftermarket rear Disc Brake ROTOR, right side, spiral drilled cooling holes, fits all XJ1100 models.
    $ 159.00
    HCP4135 Aftermarket front Disc Brake ROTOR, left side, spiral drilled cooling holes, fits all XJ650 Turbo models, and all XJ700 models.
    $ 135.00
    HCP4136 Aftermarket front Disc Brake ROTOR, right side, spiral drilled cooling holes, fits all XJ650 Turbo models, and all XJ700 models.
    $ 135.00
    HCP4137 Aftermarket front Disc Brake ROTOR, left side, spiral drilled cooling holes with a fully-floating, riveted hub design, fits all XJ650RJ Seca models, and all XJ750 Maxim and Midnight Maxim models.
    $ 195.00
    HCP4138 Aftermarket front Disc Brake ROTOR, right side, spiral drilled cooling holes with a fully-floating, riveted hub design, fits all XJ650RJ Seca models, and all XJ750 Maxim and Midnight Maxim models.
    $ 195.00
    HCP4140 Aftermarket front Disc Brake ROTOR, left side, spiral drilled cooling holes, fits all XJ900RK models.
    $ 164.00
    HCP4141 Aftermarket front Disc Brake ROTOR, right side, spiral drilled cooling holes, fits all XJ900RK models.
    $ 164.00
    HCP4139 Aftermarket rear Disc Brake ROTOR, right side, spiral drilled cooling holes, fits all XJ900RK models.
    $ 169.00
    Disc Brake Rotor Hardware:
    bh3) OEM and aftermarket disc brake rotor ROTOR MOUNTING BOLTS AND LOCKING TAB WASHERS, high-strength, heat treated bolts and double-ear fold-over tab lock washers. We highly recommend replacing the bolts each time a rotor is changed. Lock washers can be re-used, but the un-bending and re-bending of the lock ears can both fatigue and break them off.
    Use 6 bolts per rotor, and 3 lock washers per rotor.
    HCP2860 OEM front or rear disc brake ROTOR MOUNTING BOLT, used on all XJ550, XJ650, XJ750, and XJ1100 models. Each:
    $ 2.00
    HCP2860SET6 OEM front or rear disc brake ROTOR MOUNTING BOLT, used on all XJ550, XJ650, XJ750, and XJ1100 models. Set of 6:
    $ 10.00
    HCP2860SET12 OEM front or rear disc brake ROTOR MOUNTING BOLT, used on all XJ550, XJ650, XJ750, and XJ1100 models. Set of 12:
    $ 19.00
    HCP2865 OEM front or rear disc brake ROTOR MOUNTING BOLT, used on all XJ700 and XJ900 models. Each:
    $ 4.00
    HCP2865SET6 OEM front or rear disc brake ROTOR MOUNTING BOLT, used on all XJ700 and XJ900 models. Set of 6:
    $ 22.00
    HCP2865SET12 OEM front or rear disc brake ROTOR MOUNTING BOLT, used on all XJ550, XJ650, XJ750, and XJ1100 models. Set of 12:
    $ 40.00
    HCP2862 OEM front or rear disc brake rotor mounting bolt LOCK WASHER, used originally on all XJ550 models, all XJ650 Maxim except Turbo, 650 Midnight Maxim, and 650 Seca models, all XJ750 Midnight Maxim models, and XJ1100 models for both the front and rear rotors. Will fit and function properly on all XJ550 models, all XJ650 except Turbo models, all XJ750 models, and XJ1100. Factory replacement washer may differ slightly in style and appearance from original but will fit and function correctly. BRIGHT FINISH. Each:
    $ 4.50
    HCP2862SET3 OEM front or rear disc brake rotor mounting bolt LOCK WASHER, applications and fitment as listed above. Set of 3:
    $ 12.00
    HCP2862SET6 OEM front or rear disc brake rotor mounting bolt LOCK WASHER, applications and fitment as listed above. Set of 6:
    $ 22.00
    HCP2864 OEM front or rear disc brake rotor mounting bolt LOCK WASHER, used originally on all XJ750 Maxim and 750 Midnight Maxim models, and XJ1100 models for both the front and rear rotors. Will fit and function properly on all XJ550 models, all XJ650 except Turbo models, all XJ750 models, and XJ1100. Factory replacement washer may differ slightly in style and appearance from original but will fit and function correctly. BLACK FINISH. Each:
    $ 5.50
    HCP2864SET3 OEM front or rear disc brake rotor mounting bolt LOCK WASHER, applications and fitment as listed above. Set of 3:
    $ 15.00
    HCP2864SET6 OEM front or rear disc brake rotor mounting bolt LOCK WASHER, applications and fitment as listed above. Set of 6:
    $ 28.00
    NOTE: all XJ700 and XJ900 models did NOT use rotor mounting bolt lock washers.
  15. ZaGhost
    ZaGhost Member
    OK, found it easlily using that chart.... MD2014RS
    After a little cross referencing, same as the 88-90 Virago 250's &
    82 XJ 750 (right side) and 81-82 Virago 920 (right side)
    What exactly are the differences in the various rotors between the models, diameter, thickness, bolt pattern?
