what's the trick to removing the front brake light swith ?
Discussion in 'XJ Technical Chat' started by eric.jones, Jun 30, 2008.
  1. eric.jones
    eric.jones New Member
    Phoenix, Arizona
    :?: Okay what's the trick to removing the front brake light swith ? I'm afraid to pull to hard, I dont want to break something.
  2. flash1259
    flash1259 Member
    W.R. Wisconsin
    Look at the under side you will see a hole inside the hole is a tab take a small screw driver and press the tab and gently pull the switch out.
  3. wizard
    there is i little hole in the side, poke something small & round in to release the plastic switch.
  4. danno
    danno Member
    Union Springs,New York
    There is a little barb on the underside where the switch connects to the lever perch. Push this in with a nail or similar object as you pull gently on the switch,and it should come right out.
  5. eric.jones
    Phoenix, Arizona
    Re: what's the trick to removing the front brake light swith
    Yes, that's why I love this sight. Ask a question - get an answer!
    Thanks guys, I was so easy I just couldn't see it.
