not new to bikes, just to XJ's explain fuse box issue plz
Discussion in 'XJ Technical Chat' started by bigfitz52, Jul 2, 2008.
  1. bigfitz52
    I'm used to crappy electricals, I ride a Norton--what's up with the fuse box? Other than being an obvious POS (one of the fuse holders in mine was BROKEN when I got it) what is the problem?
  2. PSteele
    PSteele Member
    Nova Scotia, Canada
    Best idea is to do a search in the forum using 'fuse box'. There are many write ups with pictures and it should be Job #1 for any XJ rider.
    Good luck with yours.
  3. Nick
    Nick Member
    Vernon, BC Canada
    It's old and fails to make good contact with the fuse.
    The fuse clips can break and can leave you stranded in the middle of nowhere.
    It's old technology, not worth playing with.
    Just save some time and trouble by replacing it.
  4. wizard
    Re: not new to bikes, just to XJ's explain fuse box issue pl
    before & after.
  5. abames
    abames Member
    Northwestern Ontario Canada
    Hi Wizard,
    you mean After & Before,
    nothing negative meant just thought it a bit humourous after the jet thread (me doing it backwards to how you do it).
    BTW, where did you get that fuse box ass'y it looks great?
    TKAre,
    A.B.Ames
  6. unaverageman
    unaverageman Member
    Twin Cities, MN
    Definately neater than what have. Now I will have to redo it again lol. I will just add it to the list of things to do this weekend. We could use the make model and where to buy a nice assembly such as that though ;-)
  7. wizard
    we in the southern hemisphere always scroll up, not down.
    i keep forgeting, when posting pics, to upload the last one first, as if life aint complicated enough.
  8. abames
    abames Member
    lol,
    don't worry, if it was me they'd be upside down aswell...
    I'll also have to try to rember that (order to load pics) if i ever do post any (sure i'll forget by then though).
  9. XJ550H
    just a bump
  10. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Ah shoot thought Fitz came back!
    Stumplifter likes this.
  11. mc1oo1
    mc1oo1 Member
    LB,Ca
  12. Blackfnttruck
    Blackfnttruck Member
    Harrisburg Pa
    I think that is the one I used:
    This is the initial setup, need to clean up some of the wires and connections yet>
  13. k-moe
