750 owners, i need a reference pic
Discussion in 'XJ Technical Chat' started by turtlejoint, Jul 8, 2008.
  1. turtlejoint
    turtlejoint Member
    I have a 750 on a 650 frame and due to the way the shifter sits, it shifts backwards. Id like to see if it would be possible to get it back to a conventional status but i cant see any reference pics that give me the detail i need. can someone snap a few pics of the shifter setup on their 750 for me please? thanks in advance.
    P.S. i skimmed the gallery to no avail.
  2. osage
    osage Member
    Frost Bite Falls, MT
    I posted a pic here: XJ750 shifter
    hope it helps, it's a bit blurry for some reason....
  3. chacal
    Be aware that the picture from Osage is for a 750 SECA shifter mechanism.......750 Maxim's use a similar-but-different configuration that also requires the use of the separate, adjustable shifter plate behind the cover.
    I think you're going to have to end up getting the entire shifter cover and guts from a 650 Maxim in order to get it to shift in a conventional manner. Starting with the cover itself, there are just too many differences between the internal and external mechanism to allow for some type of "simple" fix.
  4. turtlejoint
    turtlejoint Member
    chacal,
    i agree to an extent. im thinking that i might be able to fabricate a mount on the frame somewhere to facilitate the linkage. i would just need to see if the shift linkage from a 750 maxim would overlap the frame at a point where it could be mountable.
  5. schmuckaholic
    California
    ASCII and ye shall receivii...
