Clean and Polish?
Discussion in 'XJ Technical Chat' started by lpayne, Jul 10, 2008.
  1. lpayne
    lpayne New Member
    Oklahoma City, OK
    My 1981 XJ650 that I only acquired recently has probably never been cleaned since the eighties. I've started polishing the chrome, aluminum, and every other type of metal surface. But I'm having to work through layers of oxidation and tarnish. I've tried a few different brands of cleaners and polishes.
    Does anyone have one that makes the job easier or at least faster? At this rate it'll take so long I'll have to start over once I'm finished! LOL
  2. weoxstan
    weoxstan Member
    Central Michigan
    I use 000, or 0000 steel wool to get the oxidation and rust off of mine. After that I use Mother's.
  3. brent_bastien
    brent_bastien Member
    Commerce mi
    dont use the steel wool it will impregnate the aluminum and chrome with little bits of steel which will rust and you will have to scrub again
    use a green scotch brite pad (the ones you use to scub pots and pans in the kitchen)
    i did the steel wool thing and i got the little rust spots
    with the green pads it stayed clean
    on the really corroded aluminum i used a paint stripper to get the yellowed coat of varnish off then i used a buffing wheel and some alluminum polishing compound it can take a while
    find out what parts you can take off and put an 8 inch buffing wheel in your bench grinder with the aluminum compound and you can polish the parts real quick
  4. weoxstan
    weoxstan Member
    Central Michigan
    Never thought of the steel wool impregnating the aluminum. I will switch over even though I have not had any problems as of yet.
  5. wizard
    pollishing aluminium.
    start with 80 grit oxide paper & stage by stage take it finer to 240, now use the solid pollish & the buffing wheel, finally finish with Mothers or similar.
    there is no quick fix.
  6. RickCoMatic
    Hey, Wizard ...
    Are you sure about 80 and 240?
    I have never used 80 for anything other than cutting-down body filler to get a surface close to working with the finer finishing papers.
    80 and 240 are "Scratchers"
    Cutters.
    Rough stuff.
    If you want to bring a finish to a bright alloy you'll have alot of extra work to do by starting out with such a rough abrasive.
    Peek at some of the Polishing I did in My Gallery.
  7. wizard
    Hey, Rick meister, it depends how much oxidiation is on there, i know, i have had to start with rougher suff than 80, like, wire brush.
    with small stuff, like your oil filler cap, you can just buff that from the get-go, but for broader areas you have to sand down grade by grade. if it's that good to start with, you won't need abrasive at all.
  8. RickCoMatic
    When I needed to remove the yellowed and flaking-off Factory Clear Coat; I used a Spray-on Paint Remover called: "Airplane Paint Remover'
    The stuff goes on and clings because its like a foam. I dissolved the Clear and the Paint, bubbling it up and letting you scrape-off the mess with a tongue depressor.
    It's a sure-fire way to get all that stuff right off there without a lot of elbow grease.
    Scrape-off the heavy stuff with a tongue depressor.
    Hit the nooks and crannies with a Q-Tip.
    Wipe-off the rest of it with a paper towel.
    Clean and bare bright alloy awaits finishing with ultra-fine grades of finishing papers.
    Even the toughest parts will look like chrome:
  9. gunnabuild1
    gunnabuild1 Member
    Stop showing shiny pictures Rick it makes me feel guilty.
  10. bigfitz52
    I'm a fan of the green scotchbrite pad to get the old clear coat off, as well as the worst of the corrosion. I use Solvol Autosol (a German product rather widely available) to get the shine up, then Mothers to maintain thereafter. Solvol is perceptibly coarser than Mother's. I have found that TIME also aids the process...over time, your newly polished cover WILL oxidize a bit and need to be repolished (unless you clear coat it but what fun is that?) After a few of the oxidize/repolish cycles, the stains will fade away quite nicely. I LIKE the paint remover idea, though. Rick, where do you get that stuff?
  11. chadwickm
    chadwickm Member
    Wichita, Kansas
    To make your bike look like this:
    1. Get rid of the clear coat with the afore mentioned Aircraft Stripper
    2. Start with 320 grit progressively working up to 2000
    3. Get a couple of buffing wheels for your grinder
    4. Get a bar of Red Jewlers Rouge
    5. Get a bar of White Jewlers Rouge
    6. Polish with the Red
    7. Get a mirror finish with the White
    Enjoy!
  12. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Het Chad,
    What kind of paint did you use on your cylinders. The black on mine is almost gone.
    Your bike looks great.
    Ron
  13. chadwickm
    chadwickm Member
    Wichita, Kansas
    Ace Hardware - high temp grill paint. Brushed it on by and with a cheapo brush from Big Lots. Cost MAYBE $4.00.
  14. lpayne
    lpayne New Member
    Oklahoma City, OK
    Thanks for all the info!!! I see that there may be some short cuts. I'll get some before and after pics. I just hope I can get my XJ to look as sharp as Rick's and Michael's.
  15. weoxstan
    weoxstan Member
    Central Michigan
    While we are talking about cleaning and polishing, what about the rear shock/strut springs? Any good way of getting them cleaned up? Mine are looking kinda bad.
  16. chadwickm
    chadwickm Member
    Wichita, Kansas
    On or off the shock? I disassembled the ones on my Magna and re-polished all the chrome parts. I use SOS pads for the springs, cleans them right up.
  17. weoxstan
    weoxstan Member
    Central Michigan
    I was thinking on. How hard are they to get apart, if not too bad I can take them off if it is going to be alot easier to clean.
  18. jgb1503
    jgb1503 Member
    Near Utica, NY
    I wsa thinking the same thing - mine are kinda nasty ;-)
    Can you soak them or anything? or would that ruin them? (the whole thing)
    If I can take it off, i can do the 'electrolysis' trick on the springs, that should help.. I have been doing that for TONS of parts - they come out beautiful!
  19. chadwickm
    chadwickm Member
    Wichita, Kansas
    It's not hard, just remember you will be working with a spring under compression; always point away from yourself, keep the kiddies out, etc.
    You need to make yourself a spring compressor for the shock, a couple of boards, some all thread,and bolts and washers works really well. Once the shock is compressed, loosen the nut under the top of the shock and unscrew the top. Uncompress the spring, disassemble, clean, and reassemble in reverse order.
    I'll take some pictures of my compression tool and post them when I get home from work.
  20. chadwickm
    chadwickm Member
    Wichita, Kansas
    I wouldn't soak them in anything personally. A quick wash in the sink with some hot soapy water is as far as I went.
    I would be interested in see the electrolysis results if you go that route. You may be able to start up a nice little side business referbing shock springs!
  21. jgb1503
    jgb1503 Member
    Near Utica, NY
    LOL,
    I have done the pegs, pedals, the read fender, the gas tank, a bunch of screws, the fuel sensor gauge, and a ton of misc pieces - they all come out great with a little bit of work.. I use the electrolysis, then soak in clr(with a rinse off and a good brushing each time), then soak in rubbing alcohol and let dry.. If it had rubber or plastic, I rub down with armor all... come out great!
    Would be 'very' interested to see the tool you built if you can get some pictures up, mebbe even a detailed how-to? ;-)
  22. lpayne
    lpayne New Member
    Oklahoma City, OK
    OK someone explain the electrolysis appraoch or give me a reference on the net to do some research.
  23. jgb1503
    jgb1503 Member
    Near Utica, NY
  24. chadwickm
    chadwickm Member
    Wichita, Kansas
    I think he means something like this: Electroplating
  25. wizard
    if you have got some road rash on your casings, you've got to start with a low number.
  26. weoxstan
    weoxstan Member
    Central Michigan
    Chadwickm:
    When do you get off work? I an interested in seeing your DIY Tool.
  27. chadwickm
    chadwickm Member
    Wichita, Kansas
    Sorry! Had unexpected company last night. Will get them up today.
  28. weoxstan
    weoxstan Member
    Central Michigan
    Just a reminder about the pics.
    Please!
  29. artgostick
    artgostick New Member
  30. xj550
    xj550 Member
    Airdrie, AB
  31. RickCoMatic
    You'd be better-off tackling those Mirrors with some strong Chrome Polish and a health amount of Elbow Grease.
    If their pitted, ... Aftermarket Mirrors are 17-Bucks and Up.
    If you get Aftermarket Mirrors you need a "Reverse Thread Adaptor" for the Right Hand Mirror unless the package says: "For Yamaha"
  32. NigeW
    NigeW Member
    Bradford, UK
    One more vote for Solvol Autosol. Unlike Fitz though, I'm happy to use it all the time to maintain the shine.
    It works on alloy, chrome and even painted/coated surfaces. Be careful though, as it is an abrasive polish. You can always use it on a wet cloth to lessen the abrasiveness. Just buff up when dry.
