need torque for head gasket ASAP
Discussion in 'XJ Technical Chat' started by maksrunner, Jul 12, 2008.
  1. maksrunner
    maksrunner Member
    chattanooga,tn
    i took off my head gasket and need to know the spec to put it back on
  2. Nick
    Nick Member
    Vernon, BC Canada
    12 cylinder head nuts M10 x 1.25 23.1 ft-lbs apply oil
    20 cylinder head bolts M6 x 1.0 7.2 ft-lbs
    2 cylinder nuts M8 x 1.25 14.5 ft-lbs cam chain case front & rear
  3. maksrunner
    maksrunner Member
    chattanooga,tn
    an i just get em super tight?
  4. Nick
    Nick Member
    Vernon, BC Canada
    Here's a link to the tightening sequence!
    http://www.xjbikes.com/Forums/viewtopic/t=986.html
    I guess you can just tighten them "super tight" but you would risk the possibility of warping a head, stipping a nut, blowing your new head gasket!
    I don't think it's worth it, get a torque wrench from someplace!
  5. maksrunner
    maksrunner Member
    chattanooga,tn
    i guess im tightening the cover and gasket?
    cause it wasnt those bolts
    and iv tightened things without a torque before...i usually can remember how much pressure the bolt had on it.....worked on a lot of engines haha just not bike ones
    and they werent that tight honestly...just the 4 bolts in the middle
  6. maksrunner
    maksrunner Member
    chattanooga,tn
    well i got it all back together
    it looks like a good seal...hopefully it holds
