Do any other carbs fit xj550 seca???
Discussion in 'XJ Modifications' started by sarah-jane, Jul 12, 2008.
  1. sarah-jane
    sarah-jane New Member
    :?: Does anyone know of any other carbs that will fit onto a 550 seca, I am in UK and not many early xj's about here, will carbs from a later 600 fit or something totally different, any help much appreciated!
  2. acergremlin
    acergremlin Member
    NE UK
  3. sarah-jane
    Thanks thats helpful and god knows how I missed that set of carbs as I seem to spend my life trawling ebay!!! :lol:
  4. dinoracer
    dinoracer Member
    Chattanooga, TN
    the carbs from the FJ, the radian and the FZ will fit but you will have to use the carb boots from whatever bike you get them from. The only problem you will have is if you are still running the stock airbox. If you are running pod filters then its really easy. I do not know if the other carbs will fit using the stock airbox.
    Sean
  5. sarah-jane
    Thats great news, I think I've found some fz ones so was hoping someone could confirm, I'll go and buy em, cheers!!!!! :p
  6. christian699
    christian699 New Member
    Winnipeg
    ARe 650 Seca carbs the same as 650 Maxim I?
  7. acergremlin
    acergremlin Member
    NE UK
    Yes same carbs, the 750 are also the same just need the jets swapping over.
  8. dinoracer
    dinoracer Member
    Chattanooga, TN
    Sarah if you buy the fz carbs, if I remember correctly they are the same size. The carbs from the FJ were larger. Seems the hot ticket back in the FZ days were to get some carbs from the FJ and cheat a little bit in box stock racing classes.I think the FJ carbs were 2 mm larger. I am not positive about that tho so check your carb sizes. If you do get the FZ carbs they will most likely need to be rejetted to the stock 550 airbox and exhaust.
    Sean
  9. sarah-jane
    Thanks Sean thats great, I am definitely gonna go for FZ carbs as they don't seem so hard to come by, so I just take the jets out of my old carbs and screw them in the new uns.... is that right???? Doesn't seem too hard LOL!!!!
  10. BleedingOxide
    BleedingOxide Member
    Brighton UK
    Heya,
    anyone know if this is still true for FZ750 Genesis carbs? If I get the carb boots can I fit these to an XJ550 seca?
  11. a100man
    a100man Well-Known Member
    Bedford, UK
    No chance. FZ750 carbs are down draft and mounted on a heavily forward slanted engine Completely different beast to the XJ/FJ series of engines. Even a diversion (secaII) has the downdraft style so no use looking there either. Mikuni BS 28/30/32 are where it's at. For a 550 stick with 28 or maybe 30.
    Cheers
    J
