REAR RUBBER
Discussion in 'XJ Technical Chat' started by grimreaper169, Jul 14, 2008.
  1. grimreaper169
    grimreaper169 Member
    Mims,Fl.
    I need a new tire on the rear and as yet don't have my manual. Who can tell me what I am in for? How to do it 82 xj 750 . They want $60.00 on the bike $25.00 if I bring them the wheel + $95.00 for the 190/50/16 Dunlop.
  2. Altus
    Altus Active Member
    London, Ontario
    I'm pretty sure the correct size you're looking for is a 130/90-16. Due to the shaft drive in the swingarm, nothing bigger will fit without major modifications.
    Wheel removal is pretty easy - remove the brace arm, loosen the pinch bolts, then remove the axle. You can then wiggle the wheel/brake drum assbembly off the shaft splines.
  3. grimreaper169
    Mims,Fl.
    Right you are Altus it is 130/90/16 and I will give it a go on removing the rear tire. Whats the worst that can happen? No don't tell me. Also while I'm in there I will look at those shoes. Thanks for your reply!
  4. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    Dont forget to pay attention to the spacers/spacer location.
    Also lube the parts that need to be lubed, and clean the parts that dont
  5. grimreaper169
    Mims,Fl.
    Good point Ass I will take pics that way when I forget I will have a referance. Notice I said when not if. Should be lubed???
  6. chadwickm
    chadwickm Member
    Wichita, Kansas
    Also pay attention to tire rotation direction! The tire is marked as to what direction it should rotate.
  7. Ass.Fault
    Lube points I think are:
    the splines
    axle
    someone can chime in with their thoughts on lubing
  8. yamyboy
    yamyboy Member
    Toronto Ont Canada
    may want to lube the bearings also seeing as you have the tire off. Use wheel bearing greas nothing eles.
  9. treybaxter
    treybaxter Member
    Mississippi
    Just did my rear tire. Dennis kirk delivered the rear tire (same size as yours) for $78. I put it on myself and saved myself a lot. The dealers have a big markup on tires at least around here. I second the motion for checking your spacing and direction. Easy thing to overlook till you got it on already.
  10. 85MaximXX
    85MaximXX Member
    S.W. michigan
    thats what I lubed A.F. also the bearings at least on mine weren't the repackable ones they have covers on them.
    a dab on splines and clean then thin coat on the axle. If you have a manual check the wear limit spec on your shoes the wear limit on mine are 2mm yours are probably similar. Oh and torque everything to spec or at least the axle for your own safety.
  11. grimreaper169
    Mims,Fl.
    This should be done by the guy that mounts the tire right? I would mount it except I have no way to balance it.
  12. treybaxter
    treybaxter Member
    Mississippi
    Balancing?.....We dont need no stinking balancing.....
    hehehe
    I wouldnt worry about it unless you feel a wobble after runnning down the highway. I'd save that $30.
  13. grimreaper169
    Mims,Fl.
    I can remember putting a luquid balance in my old xs 750. No balance of any kind are you serious?
  14. treybaxter
    treybaxter Member
    Mississippi
    LOL... well, granted... i AINT no veteran biker, but i put one on yesterday myself and it rides great. The way i see it, these backwoods roads i ride on everyday, i dont know what a good balance would help.
    Someone show me the error of my ways!
