Oil Capacity For '82 750 Maxim
Discussion in 'XJ Technical Chat' started by luminaman, Jul 16, 2008.
  1. luminaman
    luminaman Member
    Clive, IA
    I just purchased a used '82 750 and don't have a manual yet. I want to change the oil ASAP. Can someone tell me the correct capacity?
  2. Altus
    Altus Active Member
    London, Ontario
    Should be 3.5 Liters / quarts with the filter change. Put in 3 liters then top up as needed to get the level to the top of the viewing window.
  3. luminaman
    luminaman Member
    Clive, IA
    Right now it's in the middle when the bike's running. Should it be up on the stand when I'm checking it?
  4. 85MaximXX
    85MaximXX Member
    S.W. michigan
    yup on center stand and give er' 10 min or so for oil to run back into the bottom.
  5. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    And fill it to the top of the window.
    fill until the bubble just squeezes out of the sight glass.
  6. TIMEtoRIDE
    Beg to differ, a MiCarl trick was leave the last bit of bubble, then you can tell if your carbs flood out your crank case. Sounds like the way to go.
    How can you check your oil level if your window is completely black???
    (or actually a nice caramel blonde - - if you're lookin at coffee, you're lookin at an oil change)
  7. Nick
    Nick Member
    Vernon, BC Canada
    To check your oil, bike should be level, on it's center stand, engine should NOT be running!
  8. inno87
    inno87 Member
    Nassau County, NY
    Aside from 3.5 quarts, what oil type should uu use, and where can I get it. I wana change my oil ASAP
  9. flash1259
    flash1259 Member
    W.R. Wisconsin
    I can send you a copy of the manual , adobe pdf file actually 2 files. part 1 and part 2. i will send through a website called YOUSENDIT
    PM me your email and i will send free of charge.
  10. flash1259
    flash1259 Member
    W.R. Wisconsin
    2.8 liters with filter change is what the manual says
  11. inno87
    inno87 Member
    Nassau County, NY
    what kind of oil? i know it says 20/40 or what ever and someone told me it needs to be a certain type of oil, specific to motorcycles b/c of the wet clutch? what exactly should i look for on the oil container, and where is it sold?
  12. unaverageman
    unaverageman Member
    Twin Cities, MN
    That is somewhat of a personal preference, I am running 20/40 motorcycle oil from Mobil 1, others swear by Ams Oil motorcycle blend. I do hopwever sugest that you look for the "Motorcycle" signification on the oil that you do choose as almost every brand has one.
  13. flash1259
    flash1259 Member
    W.R. Wisconsin
    SAE 20w40 or SE10 w30
    Just go get some motorcycle oil from autozone.
  14. Altus
    Altus Active Member
    London, Ontario
    Any oil viscosity between 10w30 and 20w50 will work just fine. Smaller numbers if the weather's cooler and/or you only do short rides. Bigger numbers for hot weather and longer rides.
  15. leondegrance
    leondegrance Member
    Saginaw, Michigan
    I would go with whatever is recommended by the manufactuer. Mine is recommended to run 20W50 and I kinda like the idea of using the 50 weight as it is a bit thicker, and don't forget, this oil is also lubing up your trans.
  16. Ass.Fault
    Rotella 15w-40 is my ticket.
  17. inno87
    inno87 Member
    Nassau County, NY
    yea im gona go 2morow to pick some 20W-50 up and a filter. its like 30$ for 4 quarts and 9$ for the filter.
    oil change 2morow!!!! no more coffee :D (keep in mind i just got this bike and it sat, didnt run it like that)
  18. flash1259
    flash1259 Member
    W.R. Wisconsin
    Luminaman check you r yahoo email
  19. ericstanicki
    ericstanicki New Member
    Maine
    would someone be able to send me a pdf repair manual for a 83 maxim 750? just purchased it but have several electrical issues i need to tackle. Thanks in advance EricStanicki@yahoo.com
  20. Robert
    Ericstnicki, you need to post your question in your own thread. It is impolite to hijack someone else's thread. I'll also mention that you can purchase the XJCD and get everything you need and a whole lot more for $10. Check out the stickies at the top of the XJ Chat forum.
    Good luck to you on your new purchase.
  21. Chris Wathen
    Chris Wathen New Member
    Venice California
    I have a really nice xj750 maxim but would like to know more about the bike, I have put 500 miles on the bike since it has been rebuild, I am unsure how to check the oil level, also I want to note that I have used 10w-40 is this ok?
  22. MiGhost
    MiGhost Well-Known Member
    10w-40 is ok for light riding, as it gets hotter you might need to switch to 15w40, or 20w-50 to help avoid thermal breakdown on long high speed (hwy) running.
    To check the oil level place the bike on the center stand. At the bottom of the clutch cover will be a little window. There will be a small air bubble in the window at the correct level. When doing an oil change use approx 2.5 quarts to fill. check for leaks then top off to correct level.
    ~Ghost
  23. k-moe
    ^ that.
    The Sump capacity is cast into the clutch cover near the oil cap (2800cc), that does not include what's needed for the filter, so I drop in the 2800cc then top off after running the bike for a few minutes.
    Of important note to prevent you from having slippage problems; use JASO MA compliant oil.
