newbie help please guys (shaft drive)
Discussion in 'XJ Technical Chat' started by zoomer2001uk, Jul 16, 2008.
  1. zoomer2001uk
    zoomer2001uk New Member
    hi guys finally bought my 1st cruiser (xj 650 maxim)always had dirt and race bikes never owned a shaft drive bike before the rear wheel is off center with the tire almost hitting the shaft drive casing how do i adjust this cant see anything obvious the wheel seems to be spinning true also is there any web pages with the technical how tos for this bike as i like to work on my own bike helps to know its quirks better.
    ride hard
    die free
    ride safe
    live long
    just be happy
    riding aint wrong
  2. RickCoMatic
    zoomer:
    Go this Yamaha Parts Web Site:
    http://www.yamaha-motor.com/sport/parts/home.aspx
    Look closely at all the parts that are used to attach the Rear Wheel to the Final Drive.
    Match all the Parts in the drawing to what you have on your Bike.
    This could be a number of things. A missing Spacer. Parts out of order.
    The Wheel incompletely seated to the Drive Unit.
    You should take a photograph of the problem and Post it so we can get a good look at whats going on there.
    In the mean time. You go to the Yamaha Site. Plug-in your Bike and pull-up the schematic for that Rear Wheel.
  3. bill
    bill Active Member
    Raleigh, NC
    To throw in my 2 cents since you are new to shafts. The tire always runs close to the shaft even when the wheel is centered but close is a relative term. You should check the parts as Rick suggests to be sure your wheel is centered.
    I have owned a couple of shaft bikes - usually I get someone to hold a light above the shaft and look at the gap as I rotate the rear tire. Helps me see if it is rubbing or wobbling any.
    On my XJ the wheel is VERY close to the shaft but does not rub.
  4. brtsvg
    brtsvg Member
    Davenport, IA
    This is the normal condition on my XJ650 as well as on my 84 V45 Magna (shaft drive as well). Not a problem unless for some reason you are inclined to want to put a larger wider tire on the rear rim, at which time you'll find this will be a problem.
  5. one2dmax
    one2dmax Member
    I've got huge tires on my Vmax and some sizes rub until they get clearance. We even have aftermarket wheels that shift the centerline over to the right more to allow for larger tires. This does make it off center but they ride ok. It's harder to lean to the right and easy to the left. Some get so large (my 1500 runs a 200/50/18 vs stock 150/90/15) that we have to notch the swingarm for more clearance.
    I think on my Turbo I ran one size over and could barely move a slip of paper between the tire and the swingarm.
    Sean
  6. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    side note
    tires tend to change size!!
    They expand and contract with each revolution, temp, torque changes.
    And when you lean is when they will rub most
    edit- I happen to run a 130 on my seca's rear, 120 is stock. Have no issues yet, and I drag pegs EVERYDAY
  7. one2dmax
    one2dmax Member
    I think that's the size on the rear of my seca turbo. I have ran that size since I bought the bike back in 88 (of course it is just now being put back on the road since it sat since 94).
    Sean
