  1. Andreas
    Andreas Member
    Amsterdam (The Netherlands)
    When little things can make a big difference:
    A quite normal servicing, Oil,oil filter, Air filter, Shaft drive oil and new plugs (the good ones, NGK BP7ES in place of the BPR8ES 8O i found on.
    Just went to a 30 km (18 miles) test ride and...wow, really smooth drive, the gears are shifting in a lot better and that 10 w 40 Mineral cured also my slightly slipping clutch!
  2. coldndead
    coldndead New Member
    prescott valley , az
    not a fun day. bench sync carbs (2nd time) tried to dial them in (useing just the one gauge). plugs still have lots of yellow on tips,runs rough, just can't seam to get the sync screws to "sync". to make it worse my car died so now i have to ride my poor unhappy xj to work.oh well its only a small problem compareitivaly i suppose.
  3. chadwickm
    chadwickm Member
    Wichita, Kansas
    Pulled the tank and side covers to prep for paint. Powder coated all the handlebar control housings, MC, and bars. Nice pretty high gloss black.
  4. 85MaximXX
    85MaximXX Member
    S.W. michigan
    finally done bead blasting the swing arm, and other little parts for paint Now it is up to my friend with the paint shop he will ahve everything by the end of the day so hopefully next weekend I will be otu riding again in a new coloer and no chip, dents or scratches.
  5. mrkil
    mrkil Member
    Toronto ont.
    finished painting the tank for my cafe project
  6. stereomind
    stereomind Active Member
    Tulsa, OK
    I spent all night rebuilding the XJ1100 master cylinder, so I could mount it on the 550! :-D
    I had to switch the clutch perch as well, since the mirror angle is different.
    BTW.. the XJ1100 got a big-bore MC from mikesxs.com, and with stainless lines, it brakes with two fingers.
  7. jgb1503
    jgb1503 Member
    Near Utica, NY
    like the paint mrkil: rattle can, or spray gun?
  8. mrkil
    mrkil Member
    Toronto ont.
    thanks
    the paint is rattle can
    that pic is before clearcoat and polishing.
    i'll post a better one in a bit
  9. changingground
    changingground Member
    Denver CO
    Got her tag and registration! No more sneaking around the block. I feel like I'm 17.
  10. jgb1503
    jgb1503 Member
    Near Utica, NY
    mrkil: please do - would be interested in what rattle can type and clearcoat you used! ;-) (and how u did, you tape off the sections?? with what, etc ..etc..etc.. ;-P )
    nice job!
  11. Yamahamama
    Yamahamama Member
    Verona, WI
    I finally changed out the OE fuse box and...........the bike still runs. My first small victory!
  12. PSteele
    PSteele Member
    Nova Scotia, Canada
    Way to go Yamahamama!
    Probably the most important victory is the first small one, but in this case, very important. This is one of those jobs that you will never know if you really did any good because there will be no trouble.
    Nicely done, congrats.
  13. PaulT
    PaulT Member
    Wilton, NH
    Put my fixed ebay left side cover on.
    Still searching for the elusive right side cover
  14. sadrh
    sadrh New Member
    Kansas
    Cleaned the bike from top to bottom. Waxed the tank, wiped everything down, changed the oil, check the tires, cleaned the windjammer, took a toothbrush and gunk cleaner to the gunk off of carbs and motor. It looks awesome. I rode it for a while this evening to cool off. (It was 100 degrees today and I needed some air) The ride was short but the bike was in top form.
    Desperado
  15. sadrh
    sadrh New Member
    Kansas
    Desperado
  16. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    So this is what she looks like yesterday:
    If you want to hear her running click here and start the video. She is the loudest XJ you have ever heard:
    Loudest XJ650 YamaHOG
    So right after the video was taken I ran her a few more times until she seized on me. I pulled open the valve cover to see I was missing a cam chain sprocket on the exhaust cam. The casting was cracked across one of the bolt holes but the other one looked untouched. The sprocket blew into 5 pieces. Two halves and some debris.
    I am thinking one of the bolts holding the sprocket on backed off somehow and the imbalance caused the sprocket to shear. I pulled off the heads and the cylinders and spent about four hours fishing all the metal out of my bike. The crank sprocket looks fine. It didn't really get run with the brocken sprocket because the front chain guide wedged into the crank sprocket and prevented the engine from being turned over. I put the bike in gear and pushed the tire backwards to get the guide out of the sprocket. It was really wedged in there.
    Needless to say I'm going to put her back together tonight and try again. I'll use a cam, sprocket, and guide out of a spare engine.
    What could have caused this? I put the chain back in and there was no slack. And cranked the cam over a few times and the timing marks maintained their positions. Give me some ideas guys. I'm truly stumped.
  17. chacal
    Dude, you are one dedicated trooper! Better luck this next time!
    Mmmmm, lamb souvlaki, one of my favorites!
  18. Timetonut
    Timetonut Member
    Philadelphia, PA
    So, I got to go see Batman, and thought it was great, the only trouble was getting to the theater on time. It's only 10 miles away, and I had given myself 30 min to get gas and get there, I just didn't plan on giving the bike such a bath. In a huge thunderstorm, almost the whole way there, and after the movie (which was great and I felt obligated to shivver all the way to the end) all the way home. Lots of water in the roads, lots of lightning, and the one accident to gawk at wasn't me.
    So, I filled her up and gave her a bath.
  19. MrShake
    MrShake Member
    Normal, IL
    Dude, EXACT same thing happened to me except the sprocket stayed in one piece. Never did figure out why.
  20. turtlejoint
    turtlejoint Member
    all i did was ride it today!
  21. PaulT
    PaulT Member
    Wilton, NH
    Installed my fairing :)
    Now all I have to do is find a windshield for it.....suggestions welcome!
  22. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    I spent hours fishing metal out of my engine and rebuilt the top end... again. If you want to see the video of it running click this link:
    After two rebuilds
    Needless to say I'm going to finish the bike tonight and take her for a long run this weekend.
  23. PaulT
    PaulT Member
    Wilton, NH
    Gwyndwr, I'm guessing you're not married..
    I admire your dedication to getting that bike together. Looks beautiful
  24. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    I feel like the character Richard Dreyfus played in Close Encounters of the Third Kind. I'm completely obsessed!
    And I am married... I just don't know how much longer if I keep this up.
  25. Alive
    Alive Active Member
    Queensland, Australia
    Nice work Elvis... Had her out for that test ride yet?
    Today I think I might replace all my brakes... Not the pads, they entire brake setup.
    I've spent all week and a couple of full days last week stripping, cleaning and fitting new parts to a couple of sets of calipers, a new front master and a rebuilt rear master...
  26. Andreas
    Andreas Member
    Today i did some body work:
    I demounted the cracked front fender and let it weld by a friend,meanwhile i removed the brackets of licence plate and blinker as they was welded togheter with some steel bars in between by the PO, i guess in order to make some sort of home made top case holder.
    After i cutted and resprayed it, i forgot my rule nr. 1: NEVER, NEVER and NEVER let me with a circular saw without the supervision of an adult...so i cut the back fender just below the licence plate holder.
    Finally:
    - Took off both exhaust
    - Cried, a lot.
    - Went on e-bay and ordered a couple of new exhaust.
  27. flash1259
    flash1259 Member
    W.R. Wisconsin
    New handle bars, handlebar grips, new Mirrors and new rubbers for the pegs
    next is tires.
  28. inno87
    inno87 Member
    Nassau County, NY
    changed the oil, and bought the wrongs plugs for it yesterday .... today, buying correct plugs and gona ride a lil IF the weather holds out.
  29. stereomind
    Tulsa, OK
    Put about 130 miles on the Seca in 100F (about 38C) heat. Can you say WARM? 8O
    I think the automatic chain tensioner clicked a notch, cause my chain got quieter about 80 miles into the trip.
  30. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    Changed the oil today. I bought a Fram filter so for the first time ever, I changed the big o-ring on the filter cover. I installed the new 17mm filter cover bolt I bought this spring. I changed the gasket on the drain bolt for the first time as well. For the last "first" of the day, I used a torque wrench on the bolts.
    PS I have 54,000 kms on this bike.
  31. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    Today I just got back from a 600 mile ride through the mountains. It was unbelievable. The engine is now officially broken in.
  32. 85MaximXX
    85MaximXX Member
    S.W. michigan
    Good job Gwyndwr!! good to hear you finally got it sorted out(knocks on wood).
    Today I just looked at the bike slid it over to the wall and rearranged my friends garage. Sulked that it will be over a week still before I can re-assemble the bike ahhh!!!! I have to go out of town this week Of course when the painted parts will be done I will be 3+ hours away at work by day and motel by night till Fri eve.
  33. RPCVFR
    RPCVFR Member
    Sioux Falls, SD
    Lets see this has been over the last 3 months or so. I have been out on my bikes and have not been sorting through XJbikes much lately here goes.
    Rebuilt all 4 carbs, replaced carb holders, Colortune, helicoiled #3 spark plug hole GURRR previous owner X-threaded the plug and just kept twisting! New plugs, full Sync, changed oil and filter installed 17MM filterbolt, upgraded brakehose with stainless steel, rebuilt master cylinder and caliper installed new EBC brake pads, Installed Memphis shades Shooter windshield, replaced rear brake shoes and installed new cheap standard 25$ chain on old worn out sprockets, rebuilt tank petcock was dripping gas all over my garage floor. Hard soldered my regulator/rectifier wires due to connector meltdown. I must add that was after the H4 headlamp upgrade! Replaced turn signals with little 8W bullets, electronic signal relay "i miss my auto canceling signals =(". Had the seat recovered/refoamed, replaced battery getting ready to upgrade the chain and sprockets also it's about time for a new rear tire, and some stem bearings.
    Have been riding the crap out of this bike i enjoy the 50+ MPG and the fact that it keeps me busy learning and fixing stuff as it falls off lol. I love my Griso and my VFR but i usually reserve those for long hauls and just riding for fun. My XJ has turned into my work horse and around town traffic beater. Still love this bike and the rawness it possess, reminds me of my young days and my dads BSA without the kick starting!
  34. huckersteve
    huckersteve Member
    Seattle, WA
    Replaced my instrument cluster!!
    Working Tach now in full effect! Got 'er for $40 at Bent Bike too! (The parts kid wanted $80, but my girl hooked it up! Don't tell!)
    Installing Gamuru's replacement left hand switch for my high beams next..
  35. coldndead
    hi all. well this wknd pull'd, cleaned, #4 carb (i know,but know time for all three. still too lean on that carb but what a rocket! can't wait for next wknd for all four :wink: C N D
  36. Brtino
    Brtino New Member
    Colorado Springs, CO
    I built a new bracket for the turn signals to move them back about 5 inches so I could install some saddle bags. Then took a quick spin up Cheyenne Canon up to the falls.
  37. jonnymaritime
    jonnymaritime Member
    Montreal QC
    I took off the stock exhaust , painted the new 4 into 1 flat black excluding a ring of chrome at the end, started installing it found out I need flanges.
    painted
    the signal lights, side covers, handle bars flat black .
    changed the oil
    took off the front fender
    cleaned top to bottom .
    now playing with the mixture screws.
  38. low-1-5-0
    low-1-5-0 Member
    Newfoundland
    removed, cleaned, benched synced, set float levels, and re-installed carbs... made new idle adjust cable for easy access to adjust screw... mounted led light for plate, got bike running and idle on it's own :mrgreen: ... oil change, and bought new tires (will mount when I get it insured and on the road :roll: )
  39. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    Hmmm what did I do?
    Rebuilt it from the top up. New powder coat, paint, pistons, rings, machined the heads, different gas tank, seat, put ammo cans on as saddle bags, changed to integrated LED tail lights and signals, new handlebars, brakes, front fairing and windscreen, and then I started the engine and seized it, fished metal out of my engine for 5 hours, re-rebuilt the top end, test drove it for 1000 kms, put the carbs in an ultrasonic tank and rebuilt them, then synced the carbs, made it run really smooth, then crated it up and shipped it to Frankfurt yesterday.
    It's all done. I meet the bike in Germany on Sunday and I take a nice tour of Eastern Europe.
  40. chacal
    Gwyndwr---you're amazing. Good luck on your trip, be careful, check in with us!
  41. Gwyndwr
    Gwyndwr Member
    Vancouver, Canada
    Thanks chacal I will be careful. You can track me on my blog at:
    elvisonthemove.blogspot.com
    I will post as regularly as I can. My first stop is the Czech town of Plzen, the birthplace of the Pilsner beer. I intend on doing the Pilsner Urquell brewery tour and getting as absolutely smashed as I can off unpastuerized wood keg brewed beer and crashing at the hotel across the street. In the morning I will take a picture of my bike in front of the "World's Biggest Hangover"
  42. huckersteve
    huckersteve Member
    Seattle, WA
    Gwyndwr- Holy Moley, nice jorb! Enjoy your tour that is an awesome plan. You've certainly worked hard to make it happen.
  43. low-1-5-0
    low-1-5-0 Member
    Newfoundland
    Gwyndwr... best of luck to you... this is something I would love to do... have a blast and a safe trip!
  44. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Gwynder ... we want pics!! :)
    Otherwise... notihng new done to the XS except daily rides to work, which now includes a short higheway run, so far, she's working great... looking into some ammo can saddle bags, still need to do the cluster light-LED conversion...
  45. chacal
    Pilsner Urquell is actually my fav beer........
  46. ZaGhost
    ZaGhost Member
    mmmmmmmmmmmmm that is a tasty brew , ranks high on my list as well.... current fave is Hoegaarden
  47. Andreas
    Andreas Member
    Got rid of the original bar and put on clubmans while i'm waiting to recieve the new exhaust and the new chrome round mirrors
  48. jonnymaritime
    Montreal QC
    Today I reinstalled my PLate behind the left Rear foot peg , made a new bracket and installed A Blue L.E.D Light pod over it To make it legal. Later this week I will be making a second attempt at fabricating a new seat.
  49. xjrat
    xjrat New Member
    well, fitted a bar end mirror, made a new number plate bracket for the modified back end, fitted a 2nd hand set of carbs, £30 of ebay incl postage, what a bargain, and stripped the front brakes, hopefully ill get them back on tomorrow and a few touch ups of flat matt black ;-)
  50. stereomind
    Tulsa, OK
    Got an electronic flasher installed on the Seca. Mucho better... Seems like the signals are brighter now.
