In XJ650 Supplementary Manual...
Discussion in 'XJ Technical Chat' started by singlewm35, Aug 8, 2008.
  1. singlewm35
    singlewm35 New Member
    Carrollton, GA
    On page 149 in manual, there is diagram of rear wheel assembly.
    It shows two wheel bearings for left side(B6203 and B6203-RS) and one for right(B6303), three total. Is this correct ?
    2nd question:
    My wheels can run tube or tubeless. Is there a reason I should chose one over the other?
    Ty in advance,
  2. acergremlin
    acergremlin Member
    NE UK
    Three bearings for the back wheel is correct. Could be cheaper if you remove the bearings and go to a bearing supply shop where they can match them, i would also go for fully sealed bearings.
    Tube over tubeless, in the event of a puncture a tubed tyre would normally deflate a lot faster than a tubeless.
