Quick Dyna coil mount on XJ650G
Discussion in 'XJ Technical Chat' started by phorce1, Aug 8, 2008.
  1. phorce1
    phorce1 Member
    Silsbee, TX
    Using just 4 "L" brackets from the hardware store next door.
    The flasher relay stays where it's at.
    I haven't cut off the excess metal yet, the red sharpie lines in the last few pics are for me to follow when I do.
    The wires are ... snug .... My arthritic fingers were complaining loudly by the time I got all 4 in.
    Photos are here:
    Dyna Coil Install Link
  2. low-1-5-0
    low-1-5-0 Member
    Newfoundland
    looks good, similar to what I done... have you test fit your tank?, theres not much room under there and I ended up having to bend the brackets in putting the coils tight together under the back bone so the tank would fit
  3. phorce1
    phorce1 Member
    Silsbee, TX
    I did a test fit every time I adjusted a bolt or wire. It slides on without touching at all.
