140 90 16 rear tire
Discussion in 'XJ Technical Chat' started by 1FASTHOE, Sep 3, 2009.
  1. 1FASTHOE
    1FASTHOE Member
    GILBERT AZ.
    will it fit or will it rub ?
    and can you put the 16" rear wheel on the front ?
    85 xj 700 maxim
    thanks
  2. helmet
    helmet Member
    On 2 wheels... just lost my hat.
    140 is the width... the factory tire spec is 190-90/16
    the 140 is much narrower than the stock tire
    and you can put a 16-in up front. just not the rear.
    check maxim-x.com, they have an article on it
  3. 1FASTHOE
    1FASTHOE Member
    GILBERT AZ.
    130 90 16 is stock on my bike anything wider might rub on the drive shaft housing. just wondering if anybody has put a 140 tire on before and with any issues..?
    helmet, i'll check out maxim-x web site thanks
  4. mcrwt644
    mcrwt644 Member
    Winchester, VA
    Anything wider WILL rub. I've seen it, and I've gone from the P.O.'s 140 to a 130. It's a 10 mm wider tire the 140 is.
  5. 1FASTHOE
    1FASTHOE Member
    GILBERT AZ.
    i thought that it might. hoping i could put a little bit wider tire on just for looks..oh well
    thanks for the help
