#3 cylinder ?
Discussion in 'XJ Modifications' started by TheCableGuy, Mar 23, 2010.
  1. TheCableGuy
    TheCableGuy New Member
    why would only #3 cylinder not get any spark just a ? before i tear into the coils just in case theres some to look for all other cylinders fire great exhuast aon 12and4 r hot to the touch right after i start but 3 seem to get spark every once in a while any ideas or experince thanks
  2. skeeter
    skeeter Member
    Iron Mountain, MI
    try swapping the wires between 2 and 3
  3. streetbrawler750
    streetbrawler750 Member
    Minnesota
    Broken plug wire?
  4. bluemonster1
    bluemonster1 Member
    HOWDEN,MANITOBA,CANADA
    I have a similar problem with my 700.Sometimes starts good.Other times 2 cylinders don't fire up..not sure again which ones again,but the leads come off the coil on the right side.If I pull the wire off plugs and hold it there and then rev motor..it starts to fire and then I pop caps back on.Don't know why it does this.Your problem sounds similar in a way as mine.Cleaned carbs really good last summer and still did this every once in a while last summer.
