3 fuel tank ?s
Discussion in 'Hangout Lounge' started by cly_adams, Apr 2, 2009.
  1. cly_adams
    cly_adams Member
    LISLE,IL
    First on is, Whats the best way to clean out the tank? I ran seafoam through it the other day and noticed that the gas coming out is rusty colored. Also on the gas cap there was some "salty looking" built up So seeing that makes me want to clean out the tank completely. Anyone have an suggestions? Mineral spirts? just run out the existing seafoam?
    Second ?, Im assuing the fuel filter isnt in the greatest shape after seeing the crap come out of my tank, Can i just take the in tank filter off and add a in-line filter in? I dont see it harming anything and would prolly be easier in the long run to change out.
    What you guys think?
  2. redfire
    redfire Member
    Arkadelphia, Arkansas
    yes, inline good! I've heard of people using a battery charger and salt water to remove rust deposits inside the tank (electrolosys?) that might do the trick for you.
  3. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Keep the Filter in the gas tank. Its better for your gas in the long run. Nooo it wouldnt hurt it to just not have one, but thats twice the filtering! Thats why you put an inline filter on. The first one just wasnt doing a good enough job. And there are a couple posts on here on how to clean your gas tank. Some good stuff on here
    -SLKid
  4. cly_adams
    cly_adams Member
    LISLE,IL
    interesting... maybe i'll use some gatorade! :lol: :lol: just kidding.
  5. schooter
    you can use to cheapo and lazy way, kind of, put some nuts on a string, drop them in the tank, when its dry, and shake the snot out of it, maybe with a little gas in it, idk, then fish the nuts out and rinse with gas
  6. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    gatorade is nasty stuff....it will eat through stainless like you wouldn't believe.
    Can't imagine what it would do to steel in a gas tank!
  7. flash1259
    flash1259 Member
    W.R. Wisconsin
    COKE was said to be a great rust eater. LOL
  8. Don_A
    Don_A Member
    Shakopee, MN
    Yes, by all means add an in-line filter. It's considered a must around here. But, I don't think you want to remove the in tank filter. I think you'd loose your "res" circuit on the petcock if you remove it.
  9. Tiny
    Tiny Member
    Battle Ground, Wa
    If you plan on using electolysis pm me. I have done it on about 16 tanks so far and I think I've learned all the tricks.
  10. chacal
    The first trick being, DON'T HOOK UP THE ELECTRODES BACKWARDS!!!
  11. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Good one Chacal! I hooked up the electrodes backwards and the 1/4" rod disapeared in less then 15 minutes!!! When I removed it from the tank, the bottom of the rod was completely gone (eaten away!!) So I knew then, it must be backwards. Lesson learned.
  12. cly_adams
    cly_adams Member
    LISLE,IL
    ouch maybe i'll just stick with emptying out the rest of the gas/seafoam thats in the tank already lol
  13. PainterD
    Hooking up the electrodes backwards didn't hurt anything, just ate the steel rod off. It does clean the rust out of the tank when they're hooked up right.
    I guess I likes the concrete acid idea because it works faster ( it's free for me!) and does a great job. The acid only seems to attach the rust and not the actual metal, so there's no problem with it eating thru the tank, unless it's left in too long. I swished the acid around inside the tank for about 5 minutes, dumped it out and did it again. That made the inside shine like new.
    Both methods work equally well, the electrolosis method just takes longer.
  14. cly_adams
    cly_adams Member
    LISLE,IL
    do you know what kinda of acid it is? My dad works in masonary im sure he can get or have some.
  15. Icantinaturner
    Icantinaturner Member
    nr Gettysburg, PA
    Cly, there are as many ways of cleaning a bike tank as there are bike tanks. Some or more time consuming and hazardous than others. Forget caustic solutions and endless "sloshing " with junk in the tank.
    If you plan on doing it right and keeping the bike, do this. It is safe (baking soda, du uh), will not harm the tank and is impossible to screw up. When you're done you can toss the solution on your lawn without harming anything. The same solution will clean rusty tools and parts if you wish.
    If the tank is in good shape, not everyone even seals them and many come from the factory unsealed. Some guys air it out, toss in alcohol to absorb water, dump out and air dry again, and follow that with a little diesel slosh or just fill it with gas.
    if you seal, I wouldn't seal the tank with Kreem since friends have had problems with that stuff. This stuff is supposedly the best and you'll find a comment about it here, as well as the # of a place that will seal your tank for you. Yamaha adn POR-15 apparently makes a decent sealer too and is worth checking out. :)
  16. chacal
    And once it was finished with your metal rod, it would start eating away at any other steel, too.....namely, your tank! Electrolysis works both ways, you know.........
    But, when you hook it up correctly, it does a great job. Then just wash the tank out with Ospho (phosphoric acid) and you're good to go. If you aren't going to use the tank for a while, fog it with marine cylinder fogging oil.
    Muriatic acid (concrete cleaner) works well, too, but boy is it nasty stuff, and if (and when) you get it on you, or breathe it into you, you've got problems.
    But it gets rid of rust, no doubt!
    The tank sealers will work well IF and ONLY IF they are:
    a) applied to a PERFECTLY clean surface. This is a problematic for anyone who doesn't have the patience of Job and the steely determination of a 15th century monk.......
    b) applied EXACTLY according to the directions. This can present a challenge to people who don't read, ignore, or otherwise try and rush things and feel that directions are just a "guideline" rather than an it's-your-eternal-soul-on-the-line type of situation. By the way, the "rotate your tank slowly and evenly to coat every nook and cranny evenly with the sealant for about 20 minutes" is a real challenge, and I hope your bicep and shoulder muscles are up to that task (or you've got a helper you can swap back-and-forth with). FAILURE to coat every nook and cranny evenly will lead to thin spots; thin spots (as opposed to the adjoining thicker spots) leads to stress in the dried sealant, which leads to cracks, which leads to fluid migration UNDER the sealer, which leads to the sealer coming off in small or big globs, and then that tank is toast, and your carbs possibly become so clogged up with sealant gunk that they're next to impossible to clean, too......
  17. cly_adams
    cly_adams Member
    LISLE,IL
    haha I remember using Muriatic acid before when i was cleaning our old pateo, I was stupid enough to wear shorts definatly didnt feel good on bare skin :lol: But i will look in to it this weekend and let u guys know what happens!
  18. cly_adams
    cly_adams Member
    LISLE,IL
    So i called one of the shops my company deals with and he said he clean it pressure test it and seal it for 85 bucks seems like a good deal what u guys think?
  19. Polock
    just my opinion but i wouldn't buy a bike with sealer in the tank, who knows what it's covering up
    that rust in a tank won't hurt a thing as long as it stays in the tank
    get a few handfuls of steel somethings, i use BB's and shake for a while with water, about 1/2 gallon, drain the water and do it again till the water comes out clean
    use the garden hose, be creative, fish the BB's out with a magnet, blow a heat gun or hair drier in it while you take out the petcock and clean it up, fill with gas and some dry gas, go for a ride
  20. cly_adams
    cly_adams Member
    LISLE,IL
    Ya i did that, Had it sitting in my deep sink with a hose running through it for like a half hour :lol: its cleaned out now, just dont like the fact of seeing all that stuff come out 8O thats why i was thinking about getting it cleaned and sealed.
  21. bigfitz52
    If it's reasonably clean now and not showing any signs of EXCESSIVE rust, dry it out, reassemble and run it.
    However, I would:
    A: Install an inline fuel filter immediately.
    B: Add 1/2 cup (4 oz.) of SeaFoam to the first (full) tank of gas.
    C: Replace your gas cap sealing washer (chacal stocks 'em, cheap) and while you have the cap apart clean everything and lube the latch sliders sparingly.
  22. cly_adams
    cly_adams Member
    LISLE,IL
    already installed a new inline filter, and put seafoam in it :) the cap seems fine i did take it part and cleaned it out. And its holding the pressure with out leaks soo i might hold off on the cap part right now
  23. midnightblu
    midnightblu Member
    Austin, TX
    dont seal... you'll regret it ..... trying to see if i can post a pict of some sealer i pulled out of may tank that seafoam loosend up. PO did it all wrong. (sealed the tank with the petcock installed)
    the piece you see is 1/4 in thick and approx 11in long 4 in wide. i had this stuff clogging up the petcock, screen, filters, jets etc when i first got my bike .... this piece and all the other junk on the ground took me 2 hrs with needle nose pliers to get out....... nasty stuff
  24. cly_adams
    cly_adams Member
    LISLE,IL
    thanks for the info!
