30 second fix probly saved my bacon today
Discussion in 'Hangout Lounge' started by tinytim, Jun 3, 2011.
  1. tinytim
    tinytim Member
    western Ohio,home of the brain dead
    While checking tire pressure before a long ride today (I always check it before every ride) I noticed the washer under the castle nut on the front axle was kinda sideways,not seated under the nut.Sure enough,when I touched it,it had a pretty good amount of play due to the nut being quite loose 8O
    I had the front wheel off several weeks ago to have a tube installed.Since I don't have a manual (I know,I know :oops: ) I figured I could just snug the nut a bit,and the cotter pin will keep it from backing off.My thinking was that if it's tightened very much,it'll be hard for the wheel to turn,and hard on the bearings.While picking up the wheel from the shop,I asked him if there was a specific torque setting or anything,and he told me to do it exactly as I had planned,making me feel maybe not so dumb after all :wink:
    Obviously the mechanic and I were both wrong.Just thought I should share my stupidity so others will check their axle nuts if you've removed your wheel recently
    BTW,IS there a torque spec or procedure for that?
  2. JFStewart
    JFStewart Member
    Ontario Canada
    Maxim 550 manual says 77.5 lbs/ft.
  3. maverickbr77
    maverickbr77 Member
    Lowville, New York
    650/750 haynes manual says 77 lbs/ft or 10.7 kgs/m
  4. bigfitz52
    There'a procedure as well. Tightening the axle nut to the proper torque (77 ft/lbs) should NOT put any sort of bind or stress on the bearings, that's not how it's designed. If it DOES, you have something out of place.
    Snug, but don't fully tighten, the axle pinch bolts; torque the axle nut to spec. "Bounce" the front end a couple of times, then torque the pinch bolts to their proper torque as well. (14.5 ft/lb.) It's important that the pinch bolts NOT be tight before you torque the axle nut.
  5. tinytim
    tinytim Member
    77 8O ,wow,that seems like a lot,but if that's what it's supposed to be,I guess I'll be cranking it on down again.It was real tight when I was taking it off,but I just figured it was stuck on there due to corrosion
    Thanks a bunch for the info folks.
    Oh,1 other thing,anybody know off hand the exact size of the castle nut? I don't have any metrics quite big enough,so I just used an adjustable wrench.But of course I'll need to buy a socket in order to use the torque wench (incorrect spelling of "wrench" intentional :p )
  6. bigfitz52
    22mm. Be sure to get a 6-point socket; and use a new cotter pin.
  7. hogfiddles
    Torque wench.....hmmm.
    Dave
  8. tinytim
    tinytim Member
    Thanks again Fitz,you da man!
    Yeah,I call it a torque wench,and I meant to say adjustable wench as well :lol: I like to change the names of everyone and everything,and in some cases I make up words entirely,just something I've always done.I think it has something to do with my non-functional pea brain.Keeps me entertained anyway :D
  9. bvpoot
    bvpoot New Member
    Rocky Mountains
    Wow. My bike just came back from a local mechanic who rides a lot. He did my tires for me. I just checked mine now, it must've been 30 or 40 pounds. I snugged it until I couldn't move it any more with a crescent wrench. I supposed I got it to about 50 pounds or so. I don't have a torque wench or wrench, nor do I have a wench on the front of my truck.
    I wonder just how many people ride around with a loose nut?
  10. t-roy
    t-roy New Member
    I am the loose nut riding around. harharhar
  11. pbthoe
    pbthoe Member
    Moore, S.C.
    Most problems are caused by the "loose nut" holding the handlebars. LOL
  12. autosdafe
    autosdafe Member
    Lorain OH
    I never knew about loose pinch bolts but I did know about the torque setting.
