6mm adapters for carb synchronizers?
Discussion in 'XJ Technical Chat' started by Wirehairs, May 22, 2014.
  1. Wirehairs
    Wirehairs Member
    St. Paul, MN
    Could someone please confirm that it's a 6mm adapter that's needed when using a carb synchronizer on XJ bikes?
    Thanks!
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    which gauge(s) do you have? I have the four gauge carb sync. the adapters are 6mm but will not screw into our carbs. The vac line that comes with the set up ain't worth a d@mn. Go to a autoparts store and get enough vac line to splice into the set up. 3" piece from gauge nozzle > oscillation adapter> 12" piece>6 mm adapters w/small hole toward gauge> 3" piece to slip over carb vac port. the gold screw inside the face is to adjust the needle so all the gauges start at the same place. works great and makes the vac sync fast and simple.
    Gary
  3. Wirehairs
    Wirehairs Member
    St. Paul, MN
    I'm ordering a Motion Pro 4 column one, and the default set does not come with the 6mm adapters, so I just want to make sure that's the size I need and order the extra adapters as an extra.
  4. rocs82650
    Middle Tennessee
    my bad. idk about that one. heard it's slick tho. members have em. someone will chime in.
    Gary
  5. BigT
    BigT Active Member
    Airville, Pa
    I too have the 4 column sync tool and I also ordered the extra adapters. I did not need any adapters, the hoses slip directly on to the vacuum ports on the rubber intakes.
  6. midnightmoose
    midnightmoose Member
    York, PA
    I believe the adapters are for bikes that don't have the vacuum nipples like ours do. My buddy has a Honda Magna and his bike requires the long tube-like adapters that screw into his vacuum ports. The hoses then slip onto the adapters.
  7. Wirehairs
    Wirehairs Member
    St. Paul, MN
    But of course moose! You are right. I was watching too many synch videos on YouTube....
  8. midnightmoose
    York, PA
    Yeah it happens sometimes... even a blind squirrel finds a nut!
