81 seca 750 very dirty carbs????
Discussion in 'XJ Technical Chat' started by Jons81, Jun 4, 2012.
  1. Jons81
    Jons81 New Member
    hi everyone,
    my name is jonathan and this is the first bike I have ever owned and i pulled the carbs off and cleanned as much of the 10 plus years off sitting varnish out. i flushed all jets and floats and cleaned all of the float vlves and two of the float needles were missing the pointed rubber tip. will this effect running? I put the carbs back on and I am also trying to run with out the gas tank right now because it has to be lined. is there anything I can do because the only thing i get is it tries to start but just stumbles. never starts just kicks a little? thankyou all for looking and reading this even though its long winded and jumpes around
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    without the rubber tips on the needles those carbs won't shut off and will end up flooding those cylinders and likely your crank case as well especially if you are running off an axillary tank. Get your carbs repaired 100% or you will be running in circles until you do.
  3. Jons81
    Jons81 New Member
    thank you very much
  4. biggs500
    biggs500 Active Member
    Sherwood WI
