81 seca 750 yics
Discussion in 'XJ Technical Chat' started by bridan, May 26, 2008.
  1. bridan
    bridan New Member
    can someomne please tell me whats going on ? when i"m riding or @ idle the warning cluster keeps on resetting itself and every time it does there is a new warning that pops up, i done the search here and on my bike, and i can"t understand it headlight works ,but the tail light don"t
    ty inadvance brian
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Remove the head light and check all of the connector plugs going to your gauges. Check for "green" corrosion on any of the connectors. Check your fuse block to see if your fuse clips are bad. Good LUCK
  3. bstig60
    bstig60 Member
    Sharpes, Florida
    I think the tail light has a seperate in-line fuse.
  4. noob
    noob Member
    Southport, UK
    I had it go mad once, going down motorway and went bonkers, then told me side stand was down and it was out of oil. The tail light does indeedy have an inline fuse, up at the ingition switch I think.
