81 Seca Gauge Cluster upgrade
Discussion in 'XJ Modifications' started by Voxboy, Sep 11, 2014.
  1. Voxboy
    Voxboy Member
    Canada
    Hi. New to the board. Just bought a an 81 Seca 750. I have been searching for quite a while too see what I can use to replace the fish finder sitting on my bars.
    I have looked through a lot of threads but am having trouble finding what is the best replacement if any. Any help on this would be appreciated.
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
  3. k-moe
    There will still need to be wiring done, or relocation of the systems monitor. The systems monitor on the XJ750 is integrated enough that simply removing it will make the motorcycle inoperative.
    Here is some reading material that may help:
    http://xjbikes.com/Forums/viewtopic/p=422444.html
    There is a thread on here describing how to relocate the monitor by extending the harness, and mounting it flush to the top of the air box. There is another where a member made an enclosure for it as part of his mounting bracket for round gauges. I'll see if I can find my saved links to those, but a google search using the site:xjbikes,.com command should bring them up.
  4. Voxboy
    Voxboy Member
    Canada
    Thank you so much folks. I am taking pics of what I am doing and will post at the end of winter.
    Thanks again !!!!
