81 XJ550 maxim Piston Ring identification
Discussion in 'XJ Technical Chat' started by MJCXJ550, Jan 9, 2019.
  1. MJCXJ550
    MJCXJ550 New Member
    Minnesota
    Bought new rings Yamaha Genuine 4GA-11603-00 (R180131V) (NO.2215). Need to know which rings go in the 1st and 2nd grooves of the piston. Both rings have a RN stamped into them on the flat side and are the same size. Looking at them with a magnifying glass and I don't see any bevels/chamfers on the edge. The only difference I see is the that both are black on the flat side but on the outside edge of the ring one of them is shiny and the other is black. I am assuming the RN will face to the top of the piston but which piston groove do each of them go in.
  2. chacal
    Ring with shiny edge goes on top. Typically the numbered or lettered side faces up.
