81 XJ550 Maxim Start Button Ground Wire
Discussion in 'XJ Technical Chat' started by Pistil_Pete, Apr 14, 2024.
  1. Pistil_Pete
    Pistil_Pete New Member
    Buffalo, NY
    So I got a free 81 XJ550 Maxim and I am going through everything on it. I just went through the ignition system test steps listed on here, which is an awesome post! So I got down to the start button being the problem. I took it apart and sure enough the little nipple piece that sits between the button and the spring was warm out. I flip it over and check the continuity on all the wires and get ready to put it back together. While adding dielectric grease to the electrical connection I noticed the the plug end on the bike has 3 pins, yet the the button assembly has 4 wires. There is no connection for the ground wire on the bike side connector. I did a little searching and in another post for a 82 550 someone said that there is no ground on the 81 because the handlebars themselves are grounded, is this in fact true? Now I know what your thinking, did I try to start the bike using the button? No, I had to stop working on it for the night and have not gotten that far!
  2. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Correct, the start button grounds through the bars. Those little round buttons and the thin plastic flange are definitely not the best design. Good luck with the bike!
    chris123 likes this.
  3. Pistil_Pete
    Buffalo, NY
    Thanks! I ordered 2 new ones to replace the horn as well.
