81 xj550 seca
Discussion in 'XJ Technical Chat' started by Retro44, Jan 7, 2024.
  1. Retro44
    Retro44 New Member
    Springfield Missouri
    Changed pressure plates exactly like this forum says 7plates total I think 8 comes in the pack for some strange reason put it all back together and now shifts by foot but no gogo when you let out on clutch lever I broke the factory cable taking it apart well old cable but got a new one seems to be in the ball park thought that was the problem so I put vice grips on lever and used my new leg clutch and to no avail still same results anyone tell me where I went wrong please and thank you
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Did it engage and gogo before you did the clutch?
    Pretty sure the primary drive chain is actually the link from the crank to the gearbox on the 550 so if it didn't engage before that may be an issue.
  3. hogfiddles
    Double check the actuator lever on the clutch cover.... dot you have it set right? Did you adjust the cable settings for the new clutch?
  4. Dallaswb
    Dallaswb New Member
    Us
    Is there another part of this conversation? what thread are you with referring to
