81 xj750rh am I missing something?
Discussion in 'XJ Technical Chat' started by JubJub, Jun 20, 2015.
  1. JubJub
    JubJub New Member
    Massachusetts
    I feel like I am missing something on the front axle. I don't have a manual and cant find the schematic anywhere.
    [​IMG] [​IMG] [​IMG][/IMG] [​IMG][/url][/IMG] [​IMG]
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    The bolt locking tabs are not bent up on the rotor. Did you center the wheel prior to cinching the bolt?
    Gary H.
  3. k-moe
  4. JubJub
    JubJub New Member
    Massachusetts
    Sorry for the late reply I am working at a summer camp and have limited access to the internet. I did not center the wheel before I clinched the bolt. The only time I have taken off the front wheel was when I did some work on the front forks with my friend who has more wrenching experience and he did not I believe. How do I do that.
  5. k-moe
    Leave the pinch bolt (right side) loose. TIghten the axle nut to spec. Then tighten the pinch bolt to spec. Often it is necessary to loosen the fender, and both sets of fork pinch bolts in order for the whole front end to get back into alignment, but if all you removed is the front wheel you probably won't need to do that.
    rocs82650 likes this.
  6. JubJub
    JubJub New Member
    Massachusetts
    also my clutch has started slipping. If my steel plates aren't burnt what do I need to buy in order to rebuild it. Or is there another reason it could be slipping that wouldn't require a rebuild? Right now I have yamalube performance all purpose 10w-40. It is on the jaso list in your signature.
  7. rocs82650
    Middle Tennessee
    Tried adjusting the clutch? You'll need friction plates (probably can re-use the plain plates), springs, bolts and a gasket. The torque on the bolts must be to the correct spec. FYI Len sells everything you'll need.
    Gary H.
  8. k-moe
    How and when is the clutch slipping?
  9. JubJub
    JubJub New Member
    Massachusetts
    I have not tried adjusting the clutch, how do I do that? It slips when i give it 3/8ths throttle or more.
  10. hogfiddles
    You can't give it 3/8ths throttle.... These are metric bikes:cool:
    rocs82650 and hohenstein23 like this.
  11. JubJub
    JubJub New Member
    Massachusetts
  12. Polock
    37.5% :)
    just rebuild the clutch and save yourself a lot of aggravation
    Luis and rocs82650 like this.
  13. Luis
    Luis Member
    Seacoast NH
    +1polock
  14. JubJub
    JubJub New Member
    Massachusetts
    yea, I adjusted the clutch and it's a lot better but I will be rebuilding it as soon as I can.
