'82 650 - Back to life
Discussion in 'XJ Technical Chat' started by Vykn, Sep 3, 2015.
  1. Vykn
    Vykn New Member
    Central-East Florida
    I bought this bike roughly a month ago, took it down to frame for paint.
    Put it back together, and it ran terribly. I couldn't put it in gear without it bogging.
    Aaaaaaaand then it hit me; hit me as in the bike fell over and the 4th cylinder header touched my arm - cold as could be!
    New plugs were fouled, IG coils secondary failed the test. Cylinder 2 & 4 weren't getting any spark.
    I checked eBay to see what they were going for, unfortunately I thought I had two bad coils.
    Saw a post "82 650 Maxim 2 & 3 cylinder ignition coils", I thought to myself, is this guy wrong, or am I?!
    Looked at the pictures, and saw each plug boot had a small 1/2/3/4 sticker by the boot.
    Sure enough one of mine had 2 & 3! I had them hooked up Left side to 1/2 and Right to 3/4!
    Bike runs good, but has air pods on the carbs. Runs real rich I believe. Plugs were carbon covered within a few minutes, and it shoots coal from where I wish I had two mufflers! ;)
    Whoever runs pods, what are your mixture screw settings?!
    Thanks!
  2. Vykn
    Vykn New Member
    Or if anyone has an airbox, i'd be interested in buying!
  3. Xythin
    Xythin Member
    Grants Pass, OR
  4. jayrodoh
    jayrodoh YimYam
    Cleveland
    Same box was used on 80 - 83. Air Clnr Case Assembly 4H7-14401-00-00
  5. quebecois59
    ONe coil is supposed to fire cylinders #1 and #4 and the other coil takes care of cylinders #2 and #3, that is right.
  6. Vykn
    Vykn New Member
  7. k-moe
    used airbox boots are listed seperately most of the time.
