'82 650 Maxim conversion to dual front discs.....
Discussion in 'For Sale, Trade/Swap, Wanted' started by chacal, Aug 6, 2006.
  1. chacal
    Okay, I need all the parts that I'll need to convert my '82 XJ650J (single rotor) to dual discs. From what I'm hearing, the complete set up off a XJ750 should work. I'll need everything: rotors, hardware, calipers, brake lines, distribution block, bolts, master cylinder, forks, etc. No junk, I'll certainly be willing to rebuild the calipers & m/cylinder. Thanks.....
  2. Mitchhill
    Mitchhill New Member
    Bellingham, WA
    I have the parts you need for the swap
    1 complete fork/trees from an 83 750 maxim (air adjustable, anti dive). Great condition seals did not leak when for was removed. lowers are painted black. $90
    master cylinder/lines/calipers from an 82 750 Maxim (these brakes will fit the fork I have). Brakes worked when removed. $40
    1 750 maxim front wheel with 2 rotors $90 for the whole thing or $50 for the rotors only (rotors within spec)
    I bought these parts and was planning on doing the dual brake conversion but don't have the time. I can send pics if you want. E-mail me at atvpunk@hotmail.com if you're interested in any of these parts.
  3. chacal
    Mitch, I sent you an e-mail......
  4. ibheath
    ibheath New Member
    Nashville Tn
    bookmarking for the info............
  5. TIMEtoRIDE
    The brakes from a Seca 750 are larger = better stopping performance.
